i just got my new 2008 black 4x4 fj last week. it is great!! i had a question though. when i try to start it up, it takes a bit to turn over. i had a new chevy silverado 1500 before this, and it would start up right when i turned the key. it normal for the FJ to take a sec to turn over? im just trying to figure out if this is normal, since this is my first toyota. thanks!
Five seems to be the magic number. neeh, neeh, neeh, neeh, neeh, varoom.. Go figure... Ron
Before I changed the plugs in mine last fall, it consistently needed 5-6 cranks before running. Now it consistently fires after 2-3 cranks
I used to have a 2000 GMC Sierra. Usually, just flick the key and it was running. Until I had deposits build up on the IAC and TB, then it would fire and stall. Dealer was clueless, so I bought the factory shop manual. Had it fixed myself in an hour
I normally drive my Ford PU that starts immediately. Then when I drive the FJ I turn the key and let it go and and then realize that it didn't start and go "oh yea, the FJ, hold the key down a little longer". It's normal from what others have said here. Congratulations on your new ride.
Follow the yellow brick.
Sun Fusion AT, bunch of factory options, protective door sills, multivex mirrors, reflective tape, BudBuilt front skid, Bandi mount
i have a 08 usually takes 2 seconds tops so it sounds normal, stop worring so much you will end up with sleepless nights if you read all of these posts.
Mods:
TRD CAI
TRD cat-back exhaust
Tinted front widows
Cobra (75WXST) 3' Firestik.
Piaa 520 Driving lights.
Total chaos skids.
Rain guards.
3 inch OME lift
