Old 04-08-2008, 12:35 PM   #1 (permalink)
Catt22's Avatar
Member Number: 14770
Valve Adustment
I was going through the factory service manual and came across a section on adjusting the valves. I had always assumed that this engine had hydraulic valve lifters and there was no need to adjust the valves. The manual details the adjustment procedure and it appears that the FJ engine has solid lifters instead of the hydraulic design. The procedure also looks to be a major PIA as it requires exchanging the lifters in order to alter the valve lash. That means that you would need to do the measurements and if they are out of spec, you would have to get a different lifter of the correct height. I doubt that the dealers stock all of the myriad lifter sizes that might be required. That means placing an order and waiting. Then install the new lifters and check again. If still out of spec, rinse and repeat. See what I mean about the major PIA? Hopefully I am misinterpreting the service manual and a valve adjustment will only be required after an engine tear down/rebuild or a valve job. Twenty four valves is a bunch to deal with!
'07 Sunfusion
AT 4x4, (CQ) Convenience Pkg, (GY) Airbags, (UR) Upgrade #2, (C8) Rock Rails & Skid Plate, (DH) Towing Hitch, (WL) 17" Alloys, (Z2) 5 pc All Weather Mats/Rear Door Storage/First Aid Kit/Passenger Arm Rest, (3T) Roof Rack
MODS: TRD CAI, Spare Tire Cover, Precision Fit Ballistic Nylon Seat Covers, Warn Receiver Shackle, Sylvania Silver Star Ultra Headlights, LED Dome Light conversions, Puck Light Mod, Under Hood LED Lighting, Aux Backup Lights
Catt22 is offline
Old 04-08-2008, 02:27 PM   #2 (permalink)
bugs1961's Avatar
Member Number: 3569
Send a message via Skype™ to bugs1961
Re: Valve Adustment
Catt22 previously said: View Post
The lifters are very hard and given proper lubrication, will probably never need adjusting. I have had Toyota engines with this type of valve train for almost 20 years and have needed to change lifters only twice, and on different cars. You can use the charts and procedures in the manual to get the exact size lifter you require so you shouldn't need to repeat the process. On my '94 Camry I adjusted about half of the valves (the others didn't need it) at 110,000 mi and they still don't need any more adjustment at 193,500 mi. I check them every 30,000 mi during routine maintenance. On the FJ, it is a big job requiring the removal of the camshafts so it's clearly not a routine maintenance item. Take care,
Bugs
bugs1961 is offline
Old 04-08-2008, 03:46 PM   #3 (permalink)
Catt22's Avatar
Re: Valve Adustment
Thanks for the reply bugs! It's a relief to know that this is not a routine maintenance item.
'07 Sunfusion
Catt22 is offline
Old 04-08-2008, 03:58 PM   #4 (permalink)
1911's Avatar
Member Number: 4994
Re: Valve Adustment
bugs1961 previously said: View Post
The lifters are very hard and given proper lubrication, will probably never need adjusting. ...it's clearly not a routine maintenance item.
+1
On principle, I just checked the valves on my wife's Sequoia at 90,000 miles and they were still spot-on.
'07 FJC, '91 FJ80, '84 Hilux, TLCA # 16550
I hear mariachi static on my radio, and the tubes they glow in the dark - Warren Zevon
1911 is offline
Old 04-08-2008, 04:03 PM   #5 (permalink)
frogeye's Avatar
Member Number: 6849
Re: Valve Adustment
When I had my heads done on my 3.2 v6 Toyota engine the lifters were all still within spec. at 90,000 miles. I think a valve job on our FJ engines is something to worry about way down the road (150,000+ miles). You'll know when you drop an exhaust valve, it will not idle smoothly at all.
frogeye is offline
Old 04-08-2008, 05:04 PM   #6 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: Valve Adustment
Another good reason to use high quality synthetic oils.
DEWFPO
"Enjoying the Journey"
DEWFPO is online now
Old 04-08-2008, 06:04 PM   #7 (permalink)
IRTSYSOP's Avatar
Member Number: 9740
Re: Valve Adustment
Looks like no chance for a collapsed lifter. I'll take it!
IRTSYSOP is offline
Old 04-09-2008, 08:59 PM   #8 (permalink)
Member Number: 14403
Re: Valve Adustment
DEWFPO previously said: View Post
DEWFPO
Could be a number of things that cause of a dropped valve.
JData is offline
Old 04-10-2008, 08:44 AM   #9 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: Valve Adustment
JData previously said: View Post
I mentioned synthetic oil in regards to reduced wear on the lifters. Delaying or preventing the need for adjustment.
DEWFPO
