Old 04-11-2008, 02:19 PM   #1 (permalink)
cypilk's Avatar
Member Number: 17597
Maintenence Required
How do I turn that stupid light off? I didn't go to the dealer to change my oil for my first 5000 miles
2008 Sandstorm 6MT
265/75/16 TRD BFG TA/KO
ARB rock rails
URD short shifter
TRD CAI
cypilk is offline
Old 04-11-2008, 02:24 PM   #2 (permalink)
Crotalus's Avatar
Member Number: 15654
Re: Maintenence Required
Put your odometer to the odometer reading (not Trip A or B). Turn off your ignition. Press and hold your odometer button then turn the ignition key on (don't start it). Hold the odometer button in until the lines on the odometer display stop blinking (and there's a beeping sound too if I recall correctly) - takes about five seconds and then your set for another 5000 miles.
An FJ rolls on
hills muted by mountains pass
a true adventure
6 spd MT Voodoo Blue
Rear diff and e-locker scuba mod
CB w/ custom CB antenna mount on uppper rear door hinge
A-Trac switch installed
Custom tube bumper in the works...
Crotalus is offline
Old 04-11-2008, 02:43 PM   #3 (permalink)
dirty flores's Avatar
Member Number: 18954
Send a message via AIM to dirty flores
i dont know, but thats a good question since i dont plan on going to the stealer my self, i usually do my own oil.
did you do your own oil, andnow the change oil light wont turn off?
2007 FJ-Negro
Mods:
-Garmin Nuvi 750
-Pro Comp Xtreme Alloy Series 7289 - Cast-Blast
-Home built My Rear Gear Box
-Eddie Baure Deluxe High Back Booster Car Seat
(if you got one too, you understand)
catch you on the flip side..
dirty flores is offline
Old 04-11-2008, 02:58 PM   #4 (permalink)
etp095's Avatar
Member Number: 971
thanks for the info,mines been on for about a year.
07 sunfusion,auto,cq,dl
mods:trd's w/265/75/16 gy wrangler s/a's,pioneer avic d3 w/sirius,pass armrest,all weather mats,cargo cvr,hitch,avs bug shield,avs ventvisors,k&n filter,seat belt alarm disabled,al pro bumper/w custom brush guard,rock blockers,piaa 40 series lights,tinted windows,bandi mount,all-pro sliders(line-x"d)ome/toytec lift,all-pro engine/trans skid,wet okole cvrs,and a-trac hack.
:mods waiting to be installed:e-locker guard.
etp095 is offline
Old 04-11-2008, 04:04 PM   #5 (permalink)
Toledo FJ's Avatar
Member Number: 14676
It tells you how to turn it off in the owners manual. Crotalus has it right.
Toledo FJ is online now
Old 04-11-2008, 05:46 PM   #6 (permalink)
cypilk's Avatar
awesome, thanks!
2008 Sandstorm 6MT
ARB rock rails
URD short shifter
TRD CAI
cypilk is offline
Old 04-18-2008, 07:45 PM   #7 (permalink)
Member Number: 13549
Question Re: Maintenence Required
How much oil needs a Cruiser for an oil change?
bongo77 is offline
Old 04-18-2008, 08:05 PM   #8 (permalink)
DEWFPO's Avatar
Member Number: 7505
Anywhere from 5-5.5 qts depending on the size of the oil filter you use. I use a stock sized filter and 5 qts. puts the oil level at the top of full on my FJ.
DEWF{P
"Enjoying the Journey"
DEWFPO is online now
Old 04-18-2008, 09:13 PM   #9 (permalink)
Smile Re: Maintenence Required
Thanks!
DEWFPO previously said: View Post
DEWF{P
bongo77 is offline
Old 04-18-2008, 10:28 PM   #10 (permalink)
ikonxone's Avatar
Member Number: 10923
Send a message via AIM to ikonxone Send a message via Yahoo to ikonxone
also some other info is that those little lines that disappear will turn on the maintenance light at varying intervals. leave 4 lines on and the reading will turn on in 4k miles. leave 3 lines on and reading will turn on in 3k miles and so on.
ikonxone is offline
