Re: Will Supercharger effect off-road performance?
funny guy...funny guy. Seriously, though. will there be too much juice under the hood to provide nice, smooth off road performance? I don't want to tear anything up, and I certainly don't want too much power to effect control when off road. I value that ability of the FJ more than street speed.
Yes.. Enough horsepower will destroy anything. Most vehicles don't have enough unused strength. It's cheaper to build things just strong enough to get by. That being said, if I had the cash I'd buy one! Ron
RomaBoy previously said:
IMO, Toyota would have never released the TRD S/C for the FJC if it was going to tear up parts. Just don't floor it trying to get over that rock...
The FJ Tranny is from a Tundra, I think it has enough strength to take the abuse of a supercharger put on a 6cyl engine as opposed to a 8cly in a full size truck pulling a heavy load. The FJ is a bit overdone on the tranny side, which is a good thing. I would not worry about it.
Sun Fusion FJC 4x4, AT
OE Rock Rails, OE Hitch, OE Rack
3" Skyjacker lift
TRD Wheels
285/75/16 Cepek FC-II
KC SLim Lights
Tuffy light bar with 2 Dick Cepek C-1000's
Viair Portable compressor
All-Pro Ultimate Links
My guess is the tranny will be fine but you will likely blow a ring gear in your diff or snap a cv joint. these things are happening already on some rigs without the SC. If you are gonna offroad there is no need for an SC, you need a crawlbox like Marlin or inchworm. you need slower more creepin gears, not faster, unless you plan on doing the BAJA.
__________________ I'm a pretty straightforward guy as long as I'm not BS'n ya
I think it depends on what you mean by off road. If you mean bombing down relatively smooth two tracks or desert trails at high speed, then you'll have a blast with the extra power from a SC.
If you want to do more technical, low speed, crawling/rock applications, the get the inchworm or similar setup.
