I have the exact same issue. Except I have a loud whining noise which I thought might have been coming from the alternator. I decided to lube up the suspension and noticed the exact same thing as the pictures posted show. Taking mine in tomorrow morning. This sucks.......
Make sure you let them know to check the bellhousing gasket!
The first time around they just looked at it and said it was oil from my blown shocks, then i made them check the gaskets and they were shot.
I don't understand how a failed bell housing gasket could cause a leak. There's no fluid inside the bell housing that I am aware of. The flywheel and torque converter are protected by the bell housing and that's it IIRC. Fluid coming from the interface between the tranny and bell housing to me would be indicative of a rear main seal, the front transmission shaft seal or a damaged torque converter.
__________________ '07 Sunfusion
AT 4x4, (CQ) Convenience Pkg, (GY) Airbags, (UR) Upgrade #2, (C8) Rock Rails & Skid Plate, (DH) Towing Hitch, (WL) 17" Alloys, (Z2) 5 pc All Weather Mats/Rear Door Storage/First Aid Kit/Passenger Arm Rest, (3T) Roof Rack
MODS: TRD CAI, Spare Tire Cover, Precision Fit Ballistic Nylon Seat Covers, Warn Receiver Shackle, Sylvania Silver Star Ultra Headlights, LED Dome Light conversions, Puck Light Mod, Under Hood LED Lighting, Aux Backup Lights
That was one of the seals that were replaced. i thought i replied in this thread but i don't know where it went: there were more than 2 seals replaced and a pump replaced. In the pictures, that is all transmission fluid you see. forgive me i don't know exactly what was replaced, except for the bellhousing one.
What pump was replaced? I have been overheating lately, but showing on Scangauge and rising rapidly. My rad has been cleaned, degreased, and pressure washed. Clean filters, new Mobil1 and still running hot. Water pump maybe?
07 VooDoo C Package
Expedition One front bumper w/ 12000 LB Titan winch
2.5" Fox Racing coilovers w/ AllPro UCA's and HD links
2.0" Fox Racing rear shocks w/ AllPro Springs
295 70 17 Nitto Terra Grapplers on Stock Alloys
AllPro shock and trailing arm skids
AllPro rockblocker
Cobra CB w/ 4' K40 on BandiMount
PIAA Ion foglights
JL Audio speakers
ScanGaugeII
