I have now had my K&N drop in filter for a little over 2 weeks. My first complete gas fill up with this filter was 19 miles to the gallon. All city driving. A Cyclone air prefilter was added half way though my experiement. I want the air getting to the filter to be as clean as possible. So, I am not sure at this time just how much the prefilter added to the mileage. Anyway, another benefit that I have noticed is that the overdrive holds much longer before dropping down a gear. Probably due to the fact that more air is going into the intake. Has anyone else noticed these things with their filter? Just thought that I would share my experiences.
Zane
'07 Black Cherry 5AT, CQ, GY, UR, C8, 2Q, 37, C7, added Toyota ski rack attachments, passenger armrest, 2 rear door storage nets, K&N drop in filter, and a Cyclone air prefilter
I didn't really notice much of a difference in mine except for the fact that I had a little better air flow and a cleanable filter. You have to remember to clean it!
__________________ 2007 Titanium Metallic TLCA#16880, Gotham City Land Cruisers, Northeast Crew
RASTA Aluminum Skids Daily Driver:2005 Toyota Tacoma C cab
Zane
I would be very careful in dusty conditions. I had a K&N drop in that I pulled after the second trail. There was all kinds of dirt in my intake. Of course I am in AZ. Our dust is really bad sometimes. I don't think they have good filtering ability in very dusty conditions.
thanks
Don
Me too. I no longer use the K & N. One secret to making that filter work is the grease you need to pack around the edges to insure a tight seal. Even with that, I dropped the K & N in the dumpster.
__________________ "L'audace, L'audace, Toujours l'audace!"
THE SCORPION véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
we used to have problems with the K&N in our Cummins Turbo Diesels as it would let fine dust past the filter. Never good to see gunk building up from excess oil and dust past the filter element before it goes into the turbo. So changed over to the AMSOIL without a problem. We also recommended anyone with a AFE cone filter run a pre-filter as they originally were not true CAI and were open on top with just heatshields between engine and intake.
I got about 1.5-1.75 difference with the AMSOIL alone from oem....but also could be attributed to breaking in vehicle as well.
__________________ I have a high art, I hurt with cruelty those who would damage me.- Archilochus, 650BC
she's a "Brick.......House"
08 FJC, Brick, Auto, Nitto Terra Grapplers (295), ATrac, Locker, Budbuilt sliders, ToyTec 3" lift
I agree with this as being a primary "flaw" in some of the design to the drop in filters. I have not seen the dust issue in my intake with the K&N but I don't drive in the high dust conditions some of you west coaster/AZ drivers suffer through...
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper TrXus Mud Radial 255/85/16
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
To answer the first question. My mileage around town is between 17 and 18. So, slight improvement there. This last tank was 21.4. That consisted of highway, city, and offroad driving. Not too shabby!
I did read the thread about the MAFS going bad from oil and dust. That was going to make me get an AFE filter. However, I also read about how people on here are raving as to how well the Cyclone air prefilter works. Then I found a swinging deal on the K&N. Probably the big thing for me is that I do most of my wheeling alone. I shouldn't have to worry about a lot of dust being kicked up in front of me. I would like to think that I covered most of the areas. So, I will either have a problem with it or I won't.
Anyway, I guess I am noticing the power a touch more because I live at a much higher altitude than most of you. It is nice to feel the transmission holding the gear than listening to it drop a gear.
Thanks for the advice! I will definitely keep an eye on things.
Zane
