1grfe exposed - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 11-11-2008, 05:40 PM   #1 (permalink)
Member Number: 23491
1grfe exposed
Hi guys. I wanted to share my pics of the 1grfe. We've torn down the longblock so we can build the heads with a heavy porting, more aggressive cams, 1mm oversized exhaust valves, and stiffer valve springs.
Shimless buckets.. nice.
bowls
cowboy bebop is offline
Old 11-11-2008, 05:46 PM   #2 (permalink)
Re: 1grfe exposed
Here are the valves, stock is 36.5mm (massive) and 29mm exhaust. We plan on upgrading the exhaust to 30mm.
Something we did to fit larger valves in a similar toyota.
Onto the valve springs. We have a set of springs here that we're using with the more aggressive cams. The stiffer springs are 80lbs on the seat and 140lbs on the nose, and allow up to 10mm lift without coil bind
Stock:
Ours:
Old 11-11-2008, 05:51 PM   #3 (permalink)
Re: 1grfe exposed
Onto the block. Here is a stock piston. We have a compatable forged piston that are the exact same dimensions.
New forgies.
The rods are of an odd dimension.
We're looking to send these out to produce forged 4340 rods as well.
Old 11-11-2008, 05:54 PM   #4 (permalink)
FJCamel's Avatar
Member Number: 11390
Re: 1grfe exposed
Interesting, please do keep us updated
Mods NEVER Stop
DIGGER made
them HAPPEN !!
FJCamel is offline
Old 11-11-2008, 05:56 PM   #5 (permalink)
toytaco's Avatar
Member Number: 8667
Re: 1grfe exposed
Is this for an X-runner? Either way, WOW! Keep us updated on the final horsepower and torque one completed. Oh and since you are changing the valve springs (i think) tell us what that thing can redline to. I wish I had the resources to do something like that.
Jeff B 07, 4X4, Blk, M/T, W/E adjustable, A/P H/D rear lower links, 285 70 17 BFG Mud, Thorley Headers, A/P front bumper, DO rear bumper, DO Sliders, Titan 10,000lb winch, Budbuilt skids, Eclipse AVN 5495, Reverse Cam, CDT Audio ES "braxial" 6 1/2 speakers w/upstage, Helix A2 amp, Galaxy DX 959 CB, Bandi mount, 102" whip antenna, ext spkr. from those now useful headliner spkrs. scan gauge II. Compustar alarm, stinger battery.
"If you don't like it, change it, if you can't change it, change the way you think about it."
toytaco is offline
Old 11-11-2008, 05:58 PM   #6 (permalink)
jeshua's Avatar
Member Number: 6888
Re: 1grfe exposed
Very interesting!!! Looking forward to more development on this motor build.
What vehicle will this go in?
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 11-11-2008, 05:59 PM   #7 (permalink)
Re: 1grfe exposed
Here are some shots of the the block and the crank. The block is open deck and uses those spiny liners. Not so great for performance but there is a remedy.
The liners are literally only 5 sheets of paper thick.
Here is the crank. It looks ok, however there are some rather thin spots where the rod journals are offset:
Old 11-11-2008, 06:10 PM   #8 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Re: 1grfe exposed
Wow, thanks for sharing. Yes, please keep this post updated and alive. I'd love to be in your position, fun and interesting stuff you've got your hands into...
See me on ih8mud...
'07 GSJ15, well enhanced SOLD
'97 FZJ80 OME J
'77 FJ45
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
Old 11-11-2008, 06:14 PM   #9 (permalink)
Re: 1grfe exposed
Here are some shots of the head and main bolts along with the block itself. We're planning on having these bolts done in ARP studs.
Old 11-11-2008, 06:18 PM   #10 (permalink)
Re: 1grfe exposed
I figure not many folks are working with this motor so we may as well share. This is actually going into a Prado (Landcruiser).
Thanks!
Eric
