Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Expedition/Camping Equipment
Expedition/Camping Equipment This forum is for discussing camping and expedition equipment.
Old 03-25-2008, 11:59 PM   #1 (permalink)
Member Number: 8776
ARB Freezer solar power?
Anyone come up with a base camp solution for this yet? Searched for over an hour.
stevemacfarlane is offline
Old 03-26-2008, 12:08 AM   #2 (permalink)
cruiserlarry's Avatar
Member Number: 2011
Re: ARB Freezer solar power?
stevemacfarlane previously said: View Post
I use a Brunton 25 foldable solar panel array to keep my ARB Freezer-Fridge running on the trail. I have a 12v outlet in the roof, and the panel opens up and plugs right in. It has a 25w output, preety high for a solar panel (highest of any of the portable panels I've seen) and will run the ARB by itself in good sunlight. I have the circuit run to go back to my aux batt as well, so it can help maintain batt charge while the ARB runs off the battery...The panel is flexible, and folds up to an 8.5"X11" size when not in use...
TLCA #9632
cruiserlarry is offline
Old 03-26-2008, 12:11 AM   #3 (permalink)
homedad's Avatar
Member Number: 10257
http://ascscientific.com/solar.html
There ya go......Good Job Larry....less then 10 minutes
I like Tator Tots...
homedad is offline
Old 03-26-2008, 12:12 AM   #4 (permalink)
Fjamming's Avatar
Member Number: 6623
What about something like this: Coleman Solar Charger
CL-1200 Kit by ICP Solar
The "Power To Go" Kit
$139.99
COSTCO previously said:
Charge your batteries in your remote cabin, RV or during your camping trip. Perfect match for replacing the daily power consumption of 12V lighting systems and appliances such as coolers, small TV’s or laptops. Can also be used for charging small backup power systems.
Coleman Solar Charger:
Provides immediate charge when exposed to daylight, even on cloudy days.
Model CL-1200
Engineered to trickle charge 12V batteries, including automotive, deep cycle, traction, gel-cell, heavy-duty
Power: 1.2A, 15V (18W)
LED indicator lets you know panel is charging
Mounting screws included
Plug’n’Play® for quick connections, 10’ power cable, cigarette lighter adapter & battery clamps
Box includes:
o
(1) solar panel CL-1200
o
(1) 10’ Power extension cable
o
(1) cigarette lighter adapter
o
(1) battery clamp connector
o
(1) mounting screw set (4 screws)
(1) instruction manual
Weather proof
Dimensions: 38.9” x 14.1” x 0.91”
Weight: 10.6 lbs.
2-year warranty
Charge Controller (CC-4000):
Perfect match for solar panels generating up to 4A of charging current (12V).
Model: CC-4000
To avoid overcharging your batteries Perfect match for solar panels generating up to 4A of charging current (12V)
Intelligent PWM charge control ensures batteries reach max capacity
Nominal voltage: 12V
Max. solar panel current: 4A
Max. wire size: AWG 14 / 16 mm²
Temperature range: -15°C to +45°C (5°F to 113°F)
Box includes:
o
(1) charge controller CC-4000
o
* Case protection: IP20
Dimensions: 2.2” x 2.8” x 1.1”
Weight: 0.24 lbs.
* 2-year warranty
Sandoo Blue FJ
Walker Evans adj. F&R reservoir shocks. Pro Links. AP F&R bumpers. Demello skid. Mile Marker SE9500C. Viking Trail Line. Super Swamper LTB 34s on Tacoma wheels. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240, Powertank 10lb, Hi-Lift, Jack Mate, Pull-Pal.
SoCal Events Calendar
Fjamming is offline
Old 03-26-2008, 12:16 AM   #5 (permalink)
homedad's Avatar
Ya' gotta' love the roll up factor in this though....
homedad is offline
Old 03-26-2008, 12:18 AM   #6 (permalink)
layonnn's Avatar
Member Number: 10006
cruiserlarry previously said: View Post
Where did you pick it up and for how much??
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 03-26-2008, 12:20 AM   #7 (permalink)
Member Number: 2011
homedad previously said: View Post
And it's more compact, waterproof, and more powerful. But it is also much more expensive, although I can tell you it work very well for all types of accessory charging (Ipod, phone, VHF / UHF radios, etc...) in addition to helping out with the battery and ARB...
TLCA #9632
Old 03-26-2008, 12:20 AM   #8 (permalink)
Fjamming's Avatar
Member Number: 6623
Looks like it's been replaced by 26. http://www.brunton.com/catalog.php?subcat=7
Sandoo Blue FJ
Fjamming is offline
Old 03-26-2008, 12:27 AM   #9 (permalink)
timbo2's Avatar
Member Number: 3828
Dick's Sporting Goods carries the Brunton. Tim
timbo2 is offline
Old 03-26-2008, 12:28 AM   #10 (permalink)
homedad's Avatar
I live in the desert....my whole roof should be made outta' that stuff.....
homedad is offline
