Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Camping Equipment
Camping Equipment This forum is for discussing camping equipment.
Old 03-29-2008, 02:51 PM   #1 (permalink)
COOKN's Avatar
Member Number: 15174
C02 or On Board Air
Comptemplating on-board air and/or C02. Suggestions? Don't really understand the C02 except what I read about initial cost. Cost to refill bottle?
Thanks for your help & thoughts in advance.
TD
COOKN is offline
Old 03-29-2008, 03:38 PM   #2 (permalink)
FJ Tex's Avatar
Member Number: 11533
Re: C02 or On Board Air
COOKN previously said: View Post
TD
lots and lots of guys really like CO2. i've seen it in action and it is pretty neat. a lot of it depends on your situation. if you plan on doing any kind of serious expedition or multi-day 4x4 stuff i personally wouldnt reccomend CO2, purely because i'm very much a fan of redundancy. i'd much rather have a permanent on board compressor and tank setup. i've heard of guys running air tools off CO2 but i've never personally dne it and i'm just not comfortable with the idea of a non-renewable tool like compressed air on the trail. the advantage also in favor of a compressor is if you ever decide to go with an air locker you're already setup with air. i'm not downing CO2 because as i said lots of guys swear by their CO2 tanks, jsut consider the pros and cons of both systems, on the upside for CO2 users, there is no need to worry about compressors overheating or tank leakage etc. you've got what you've got, and as i understand the CO2 tanks are deceptively high capacity. as far as cost is concerned, once you're out, you're out, AFAIK those tanks are somthing like 600psi, so you cant refill them yourself, but for a nominal cost a gas companycan do it for you
FJ Tex is offline
Old 03-29-2008, 04:54 PM   #3 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
CO2 can run air tools and it fills your tires MUCH faster than a compressor.
As was stated, the compressor is very redundant.
I have CO2 but don't air-down and then air-up a lot on the same run. And when I want to FILL the tires, I don't want to wait, eat lunch, go to the next tire, read a book, go to the next tire, etc.
The compressor is ultimately more practical. It depends on your use.
How does the Dept. of Transportation
convince deer to cross the road where
these signs are displayed?
uphill is online now
Old 03-29-2008, 04:58 PM   #4 (permalink)
targa88's Avatar
Member Number: 11127
Send a message via Skype™ to targa88
Depends on your usage. IF you have an expedition vehicle and you are traveling off the beaten path you might have some challenges finding a place to refill your CO2 tank.
In terms of speed CO2 will generally refill your tires faster then an air compressor.
If you are planning to have an air locker or air tools then the compressor route would be better.
In terms of economics a good compressor set up with auxiliary tank can cost $400+. Buy once ...cry once!
C02 systems $200-$300 depending on the size of the tank + periodic refills ($15-$20).
targa88 is offline
Old 03-29-2008, 04:58 PM   #5 (permalink)
COOKN's Avatar
FJ Tex previously said: View Post
I wonder how long a tank last? Will it air all your tires up after lowering pressure for trail use? Also does the guage tell you where you are on the tank? Any idea on cost to refill? Sorry for all the ?'s---just trying to learn.
COOKN is offline
Old 03-29-2008, 05:02 PM   #6 (permalink)
COOKN's Avatar
targa88 previously said: View Post
Thanks for the info! Where do you get the C02 refilled?
COOKN is offline
Old 03-29-2008, 05:03 PM   #7 (permalink)
FlyNdrive's Avatar
Member Number: 2715
I use a Viair 450C with a constant duty compressor and a 2.5 gal air tank. When wheeling I keep the tank full and when I have to air up I don't really have to run the compressor.
It never has to be refilled and the tank and compressor are tucked away well under the vehicle.
-Ben
Chairman of the Board FJ Bruisers 2007 FJ in Sun Fusion FJ, CP #2
ARB Bull Bar W/Warn M8000 & IPF's, ARB Rear Bumper W/Warn M8000 (both W/in-cab switch) and swing out tire carrier, OME 3" lift, Safari Snorkel, Eclipse AVN GPS,DVD,CD,Sirius & B/U cam. AR Craters, W/ McT 35" MTZ's, ARB Rack W/ ARB Simpson II tent, ARB Sliders, VIAIR 450 & tank, Dirty Parts 2 Battery W/ 2 Optimas, All-Pro skids, U&L links, A-arms, Cobra 75WX,ScanGuage 2,Toshiba Tablet PC W/ Topo USA 6 on A2A mount.
FlyNdrive is offline
Old 03-29-2008, 05:07 PM   #8 (permalink)
COOKN's Avatar
FlyNdrive previously said: View Post
-Ben
Where did you mount the air tank?
COOKN is offline
Old 03-29-2008, 05:41 PM   #9 (permalink)
FlyNdrive's Avatar
Member Number: 2715
Old 03-29-2008, 06:11 PM   #10 (permalink)
Decidion's Avatar
Member Number: 13809
I ended up going with a small portable compressor that just clips on the battery. Most of these kinds of compressors are garbage, but I know more than a few folks on the boards here (as do I) have the MasterFlow brand. They are actually pretty good and cost much, much less than a CO2 or Compressor/Tank system.
Sure you cannot run air tools off of it (but I don't have any anyway). Some folks say it won't work if you cannot start your engine...but if I can't start my engine, well in most cases...I not too sure I would be that worried about air down tires....I'd be fixing the engine. I am sure there are situations where my engine is dead, but I would still want fully inflated tires, but those are probably going to be rare, especially on our late model vehicles.
I'm not knocking a good CO2 or Compressor/Tank system, I'm just saying for my needs the small portable compressor works fine....and the best part is that you can get these for about $50.
Also, using my portable, I can air up from 20 PSI to 44 PSI in about 3-4 minutes per tire. To do all four, including hooking up to the battery takes a little under 20 minutes...not really that bad. Maybe you can save yourself 10 minutes with a CO2 system, but it will cost your wallet. Time is money
Decidion (Jeff)
'08 Brick Red
CF-CQ-UR-3T-C7-2Q | OEM Brush Guard || OEM Rock Rails | Tail light Guards | Magnaflow 11226 | AFE CAI | Bud Built Skids | Custom Console | VentShades | SCUBA Driver Mod | Blacked-out Bumpers | Rear Storage Shelf | IPF 968s w/Clear Covers | BFG 285/70R17 A/T KOs | SAW RaceRunners | Hi-Lift Extreme | Staun Deflators | Midland 75-822 w/Bandi Mount | OXT Shock Guards | Tantrum Rock Lights | Kelty CarTarp
Decidion is offline
