Go Back   Toyota FJ Cruiser Forum > FJ Cruiser Technical Articles > FJ Cruiser Technical Articles
FJ Cruiser Technical Articles The articles contained in this section have gone through the staging area below and have been approved to reach the "Technical Article" stage. To propose a new Technical Article, please do so in the "Living Posts/Staging Area" section.
Closed Thread
Old 10-22-2007, 06:34 AM   #1 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Thumbs up FULL-LENGTH MODULAR STORAGE SYSTEM: The "BOX"
To read the original full thread and post questions/comments on this topic, please go to Ladies & gentlemen, may I present to you . . . the BOX.
and
The BOX revisted: final wrap-up.
I began planning this project about a month before I even bought my FJ. And, it was about two months in the designing and actual building stage (a lot of hit & miss) when time permitted.
I wanted a rear storage unit that would meet this criteria:
Cost under $200 total. (I was too cheap to go out and buy something already built. Plus, there were no aftermarket systems that provided exactly what I wanted and needed.)
Be a modular system that could either be used as a rear cargo area storage box only, or a full-length system that could occupy the back seat area as well. (Since I had no use for the back seats, I removed them completely shortly after the FJ’s purchase. However, the cargo area only module could be used for those wishing to retain their back seats.)
Be sturdy enough to carry anything from off-road recovery equipment, to tools and parts, to camping gear, to miscellaneous supplies and gadgetry.
Be completely removable and returned to stock configuration if desired.
Use existing OEM bolt and mounting holes without any cutting, drilling or otherwise molesting the FJ’s original state.
Follow the contours of the FJ’s interior design.
Be professionally-built looking (even though I’m not a professional, nor do I play one on TV).
Supplies required:
Two 4x8 sheets of ¾” plywood.
About 40 feet of ¾” aluminum angle.
2 sets of 24” heavy-duty drawer sliders.
One and a half 6’ x 8’ rolls of gray indoor/outdoor carpeting (from Home Depot @$15.95 a roll).
Carpet adhesive.
Miscellaneous hardware and screws.
I began by building the rear drawer storage box with a center divider and pre-installed the drawer sliders. The box was carpeted prior to installation in the truck. Aluminum angle iron was installed along all edge surfaces and filed smooth. (I used 3" L-brackets to set up the shape of the box until the actual 2" wood screws were installed from the outside.)
I removed the rear tie-down hooks and used their holes as the rear attachment points for the box. (I installed the previously removed tie-down hooks on the forward section of the box to secure it with a pair of turnbuckles to the other set of tie-down hooks.)
Two drawers were built, carpeted, and aluminum angled.
The forward module was created by first cutting to size a base platform that slid snugly up against the rear divider wedge. To level the platform perfectly, I attached pedestal shims along its front base.
The sides of the forward module were installed to meet the height of the rear box, and the front face panel was attached. Upon completion of the structure, I removed the entire forward module to carpet and aluminum angle the edges.
The forward module was re-installed and secured to the side bolt holes that were previously occupied by the back seat attach points. The front of the forward module was secured to existing bolt holes under where the back seats once were. (Eventually, a pair of filler panels were built to fill the spaces between the rear and forward storage boxes.)
The forward module top surface area was measured and a top was created, notched for contour, carpeted and aluminum angled.
The open-able top was attached to the face of the rear storage box with a 45” heavy-duty continuous “piano hinge.” (I’m awaiting the arrival of a flush-mounted lockable latch handle for securing the forward lid when closed, and a pair of hatch struts to hold the lid open when in use.)
(Continued in next post.)
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 10-22-2007, 06:35 AM   #2 (permalink)
Member Number: 8627
Re: "The BOX" . . . . full-length modular storage system for the FJ.
But, wait . . . . there’s more!!
Here’s something to sleep on . . . . .
With the front seats all the way forward, there’s an additional 19” of space that could easily be filled by an additional panel. So, I did.
I attached a pair of footman loops to the front section of the forward module, and fabricated a pair of aluminum L-brackets / slot-hooks to the rear of the additional panel. And, attached a pair of ½” threaded female pipe flanges to the front of the panel.
Screwed into the flanges are a pair of painted steel “legs” that provide forward support for the panel. (Rubber cushion tips for the bottom of the legs.)
Now I have a 72” long sleep surface that (snugly) accommodates an inflatable full-size bed air mattress and allows the rear door to close.
Edit: Correction . . . turns out this is a queen-size mattress. See Post #30.
When the sleep panel is not in service, the legs remove and clip to the bottom of the panel. And, the panel itself stores perfectly into the base of the forward module box.
I’m 6’ 4” and 250 pounds, and the bed fits me quite nicely, with plenty of room to spare.
Well, that’s it. During the course of building, a few scuffs found their way to the interior plastic. However, I came in well under budget. And, the storage boxes and drawers do exactly what I had envisioned.
Time for a rest . . . . .
Part 2 of this project continues in:
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 10-22-2007, 06:38 AM   #3 (permalink)
Member Number: 8627
Here are the basic dimensions of the entire set-up:
Disclaimer: The following measurements were for the unit that I built for my particular FJ. The actual size may vary for yours. And, the thickness of the carpet, the angle aluminum and your individual construction style may have an effect on dimensions as well.
So, I suggest that you just use the above dimensions as a base reference only. As they say, "measure twice / cut once."
All wood is (true) 3/4" plywood
Rear drawer box (exterior dimensions)
42"w x 10 1/4"h x 27 1/4"d (with a 3/4" thick divider mounted dead center).
Drawers x2 (exterior dimensions)
19"w x 8 1/4"h x 25 1/2"d, with the face panel being 1" taller to allow 1/2" overlap at the top and bottom of the the front of the drawer.
Note: Drawers must have exactly 1/2" clearance on each side to accomodate the thickness of the sliders. And, you'll probably have to notch the 1" front aluminum facing over the center divider to allow clearance of the drawers and sliders opening.
Forward storage box
Base platform: 45"w x 20 1/2"d.
Side panels x2: 6"h x 19"d (with a 1" 45 degree notch at the lower rear).
Front-to-rear filler panels x2: 6"h x 11"d.
Front panel: 45"w x 10 3/4"h.
Top / lid: 45" w x 24"d (with 2" 45 degree notches at the rear).
Sleep Platform
40 1/2" w x 18 1/2" d.
Total leg height (including mounting flange and cushion tip) from bottom of panel to floor: 18 1/4"h.
To be on the safe side, I highly suggest that you tape off any areas of your plastic interior that may come in contact with the units during installation. (I learned the hard way by putting a couple of nasty nicks above the rear interior wheel wells.)
Also, shims may be required for precision alignment and height adjustment of the front and rear storage areas.
Good luck. And, if you have any questions or get stumped along the way, feel free ask away.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 10-22-2007, 06:39 AM   #4 (permalink)
Member Number: 8627
I have since replaced the simple slide latches on the drawers to the heavier-duty rotating style. Substantially more secure and completely removed "drawer bounce."
Also, I installed the OEM tie-down hooks on top of the rear section for securing a variety of items. (Flashlights, cell phone, groceries . . . .)
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 10-22-2007, 06:41 AM   #5 (permalink)
Member Number: 8627
Okay, a final wrap-up of a few more things that has now completed the "BOX" project.
I initially tried a hatch/window strut to keep the forward storage box lid open, but even the lightest-duty strut I could find was overkill and popped that sucker open like a catapult. So, I went with a pair of Stanley adjustable-friction chest lid prop supports. ($5.95 each. Mounting location template is included with the supports.)
I installed a rounded low-profile handle for the forward lid, and added a flush-mounted key lock (1 1/8" long cylinder to account for the 3/4" lid thickness, carpeting and lower hardware).
For additional hold-down support, I fabricated a pair of 1" aluminum brackets that attach to the bottom of the forward storage box and bolt onto the exisiting previous rear seat mounting holes.
I added four FJC tie-down hooks to the top of the rear storage area (ice chest, additional storage boxes, etc.). A small notch had to be cut on the rear panel of the two drawers to permit opening/closing with the slightly protruding underside hardware of the tie-downs.
And, to answer the numerous PM inquires about the contraption mounted on the front of the forward storage box, it's an electrical remote-activated shotgun lock/rack system.
A disguised button on/near the dash releases the spring-loaded lock and allows quick removal of the weapon. (Supplied keys can also open the lock manually.) They're about $90-$130 from most law enforcement supply companies (i.e, Gall's).
Again, if you're undertaking this project (or something similar to it), please feel free to ask any questions you might have. Thank you again for your appreciation of this little endevour.
For the version of this thread that includes all readers' questions and comments, go to Ladies & gentlemen, may I present to you . . . the BOX. and The BOX revisted: final wrap-up.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Closed Thread
