Go Back   Toyota FJ Cruiser Forum > FJ Cruiser Technical Articles > FJ Cruiser Technical Articles
FJ Cruiser Technical Articles The articles contained in this section have gone through the staging area below and have been approved to reach the "Technical Article" stage. To propose a new Technical Article, please do so in the "Living Posts/Staging Area" section.
Closed Thread
Old 10-14-2007, 02:58 PM   #1 (permalink)
k44
k44's Avatar
Member Number: 14041
CENTER CONSOLE EXTENSION: Modification w/ pics
To read the original full thread and post questions/comments on this topic, please go to Console on Console
Over the past week, in my spare time, I built this console out of 1/2" MDF, glued and screwed, then sanded to brake the sharp edges, and then painted with contact cement and covered with fabric-backed vinyl.
It sits on top of the original console and can (for now) be removed just by lifting it up.
I set the armrest height to be the same as the door armrests, and aligned the compartment to the storage compartment of the original console below it, which makes the compartment taller and a little wider at the top.
The console armrest is closed cell foam, Ensolite, glued to a 1/2" MDF backing, and then covered with the same vinyl, and piano-hinged at the rear. Cost me $30 to have the vinyl sewn professionally.
I also have construction pics if anybody's interested.
View from driver's side.
Another view same side.
Armrest is same height as door armrests.
Had to finesse some by the brake handle.
View from rear passenger driver's side.
I made it longer than the original console to make sure I had a complete armrest area and it wasn't just lip service.
View from passenger side. Cupholders are just dropped-in right now and the passenger side cupholder is a bit out of place in this picture.
--Mike
'07 SunFusion 6MT
k44 is offline
Old 10-14-2007, 06:26 PM   #2 (permalink)
k44
k44's Avatar
Build Pics
Brand new '07 6MT September 30 2007
First step was to mock up the concept with foam core. The walls are 2.5" tall in the mockup; eventually changed to 3.5" for the actual prototype.
After a number of hours with the compound saw, table belt sander, and portable belt sander, the rough form takes shape. It was a challenge to get the pieces all perfectly cut with right angles when required. Some pieces are angled: The parking brake stub-wall, the front wall, and the rear wall. The three side-walls, and the interior wall, are vertical.
Because I knew the stock console has a crown to it, I set the flat-bottomed skeleton assembly of walls (everything but the top panel above) on 1/2" blocks along the sides of the console, and then transferred the contour of the crowns across the center, onto the internal ribs and exterior walls. Then tuned them in with the two belt sanders. I had to do this before gluing on the top (shown already in place here), but I didn't take any pictures of that.
You can see how the interior walls are notched and curved to fit the top of the original console.
Here's how the compartment looked at this point.
These cupholders came off Ebay, for $1.98 for the pair, plus $6.50 shipping. Also you can see my first prototype of the cushion. Decided the curve was stupid, and would make it harder to cover. Sawed the front of the cushion off, making it a rectangle. Sawed MDF and foam in the same cut.
I had to test the 32-oz Big Gulp for tipover behavior. Passed. Cupholders are 3.375" deep.
Gluing on the vinyl is pretty tough to do. Contact cement is not easy to work with. Add the fine cutting of vinyl at the corners (or near the corners) and it's about all I can handle. Took no pics of this. It was hard enough already.
Test fit. The contours are a go. It's solid.
Here's how the compartment looks now. But I don't know if I'm going to keep it this way. I'm thinking of adding a floor with a pumpkin-lid type opening in the floor to permit access to the lower compartment. That's the tip of a flat-blade screwdriver inside.
After getting the cover custom sewn, I routed out the appropriate positions along the hinge, and at all 4 corners, so that the double-layered vinyl at the seams would not lift the cushion assembly away from the main console top. Then I stapled vinyl and final-screwed the piano hinge (pilot holes were added before any vinyl was applied to either piece). The going gets stressful at this point because nothing has gone seriously wrong yet. Had to try pretty hard to keep things perfect because I had never tried various operations like routing for clearance and stapling...I guessed on the pre-stress to the vinyl as I stapled. Turned out to be about right.
And finally, the finished product.
--Mike
'07 SunFusion 6MT
k44 is offline
Closed Thread
