Go Back   Toyota FJ Cruiser Forum > FJ Cruiser Technical Articles > FJ Cruiser Technical Articles
FJ Cruiser Technical Articles The articles contained in this section have gone through the staging area below and have been approved to reach the "Technical Article" stage. To propose a new Technical Article, please do so in the "Living Posts/Staging Area" section.
Closed Thread
Old 03-21-2008, 08:09 AM   #1 (permalink)
The Stig's Avatar
Member Number: 16839
FRONT RECEIVER WINCH MOUNT: Inst. w/ pics
To read the original full thread and post questions/comments on this topic, please go to Modified Curt front end hitch reciever + alternative installation
What I did was take a curt front hitch reciever and modify it so instead of it going below the bumper bar, it goes above, thus allowing you use it as a winch mount.
Step 1
Chop it up real good. I cut off the tow points and the part of the hitch reciever that gets bolted onto the fj's tow points.
Step 2 - the slot
Of course there are different ways to cut the slot. (I used a band saw)
Drill holes for a slot
Step 3
cut the slot out. I used a band saw.
Step 4 - Intsallation
To get it on the FJ I had to remove the bumper, move the AC line, then chop a little bit:
Then drill some new holes for the bolts.
The test went well. I pulled on a tree untill it stalled, kind of scary but necessary. I've got a video of it but i need to edit out the swearing(the winch was doing weird things, turned out I had, sort of, screwed up the motor when I wired it, but I managed to fix it in the end)
Hope that was clear... I'm not sure if anyone else would ever try this, cheap but fabrication-requiring, way to a winch mount but I'm pretty dam happy with it.
Could someone who knows alot about torquing bolts tell me what sort of torque I should put on the bolts that hold this thing on?
Here some pics of how it looks with the bumper on.
08 4x4 AT, OR Package. Tires: 285/75r16 Yokohama Geolandar A/t-s.
Mods & accessories: Front hitch receiver, Smittybilt XRC8 winch, Snow Chains, $37 CB set up(works too)
Latest Vid: http://video.google.com/videoplay?do...20227075&hl=en
The Stig is offline
Old 03-27-2008, 01:30 PM   #2 (permalink)
NCFJ's Avatar
Member Number: 8585
To read the original full thread and post questions/comments on this topic, please go to 2" Front Receiver for Winch Multi Mount
My FJ is a dual-purpose machine, a daily driver and an off roader. I also take long trips in it as well. It should come as little surprise that I have an overall weight saving program in mind as I add MODS. When the time came to start thinking about a winch I thought why carry that extra weight around all the time when I only will be using it off road. That is when I decided to use a multi mount on a 2” receiver. It will also serve as part of a future bumper build.
Now before some of you go off about how a 2” receiver wont handle the stress, yada yada yada, save it. The Multi mount has been proven over several years and I am comfortable with it’s use. After all it is my rig and in the end if it fails it is my problem.
I was inspired by another forum member who I’d like to thank but I cant find the thread
The photos and captions speak for themselves.
1-Stock without bumper cover (what a POS that thing is)
2-AC line standoff, this will be modified to hold AC line once moved back toward radiator
3-Bumper standoff, not holes, these will be used as a mounting point for 2" receiver
4-2" receiver raw, front
5-2" receiver raw, rear view
ID:	22999  front-receiver-winch-mount-inst-w-pics-copy-p3240012-custom-.jpg.JPG
ID:	23000  front-receiver-winch-mount-inst-w-pics-copy-p3240013-custom-.jpg.JPG
ID:	23001  front-receiver-winch-mount-inst-w-pics-copy-p3250015-custom-.jpg.JPG
ID:	23002  front-receiver-winch-mount-inst-w-pics-copy-p3250016-custom-2-.jpg (2).JPG
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
My FJ may be new, but this aint my first rodeo
NCFJ is online now
Old 03-27-2008, 01:33 PM   #3 (permalink)
NCFJ's Avatar
Member Number: 8585
Re: 2" Front Receiver for Winch Multi Mount
1-Test Fit Raw
2-Test fit-side view
3-Painted and installed-front view
4-Painted and installed-side view
5-Back together ready to go to work
ID:	23004  front-receiver-winch-mount-inst-w-pics-copy-p3250019-custom-.jpg.JPG
ID:	23005  front-receiver-winch-mount-inst-w-pics-copy-p3260020-custom-.jpg.JPG
ID:	23006  front-receiver-winch-mount-inst-w-pics-copy-p3260021-custom-.jpg.JPG
ID:	23007  front-receiver-winch-mount-inst-w-pics-copy-p3260025-custom-.jpg.JPG
NCFJ is online now
Old 03-28-2008, 06:29 PM   #4 (permalink)
NCFJ's Avatar
Member Number: 8585
jamesart86 previously said: View Post
Any pics with a winch mounted?
Ask and you shall receive. Mounted front and rear, also good for airing up tires at the end of the day.
ID:	23009  front-receiver-winch-mount-inst-w-pics-copy-p3270029-custom-.jpg.JPG
ID:	23010  front-receiver-winch-mount-inst-w-pics-copy-p3270030-custom-.jpg.JPG
ID:	23011  front-receiver-winch-mount-inst-w-pics-copy-p3270031-custom-.jpg.JPG
NCFJ is online now
Closed Thread
