To read the original full thread and post questions/comments on this topic, please go to TECHNICAL SERVICE BULLETINS (TSB's): For the FJ Cruiser
Here is an ongoing list of known existing TSB's (Technical Service Bulletins) for the'07 and '08 FJ Cruiser.
If you know of any TSB's, please post the TSB number, a brief description of the problem/fix and any links that detail the TSB in TECHNICAL SERVICE BULLETINS (TSB's): For the FJ Cruiser. They will be added to this continually-updated list. Thanks.
BR8005 - Front brake noise while in reverse.
Brake Noise When In Reverse
DL003-07 - Front and rear differential gear oil specification change.
Differential Gear OIL *TSB*
EG050-07 - Oil leak from front timing cover.
BO007-07 - Access door water leak.
NV001-07 - Inside door handle creak.
AX006-06 - Roof rack rattle noise.
AX002-07 - Gap Between Front Bumper Fascia and Skid Plate (Skid plate shim kit).
06V235000 (Recall) - Tire Inspection/Replacement.
AU002-06 - Poor sound quality for satellite radio.
PA003-07 - Paint-Colors/Scratch resistance & anti-acid paints.
AU004-07 - Audio system-Noise when using an external device.
