Alright felllas, I decided it would be better to talk about the rest of the going ons with my jacked up (no pun intened) FJ.
I will be by there early in the AM. So, let me know when you guys roll in, and Ill be in behind you about thirty minutes to let the coffee kick in.
I will need to go ahead and purchase all related bearings, seals, and o-rings. If they are in stock if that is...here are the part numbers to make it easier for yall....
43750-60010
90301-92003
90312-96001
The first is the bearing...and I forget which is which on the other two (seals or orings). Cost on those are so close to your price there is no reason for me to have them shipped up here from Houston. The knuckle is scheduled to arrive at my office Friday.
Chris, what is the cost for you to do the estimate? As we discussed on the phone you mentioned other things may have been damaged and we need to be sure what all is needed to make the repair jobe done correctly. A local shop did go ahead and do an alignment as to be able to tell where the problem is last week, that is when I found out about the knuckle being bent.
I am having the body work done in houston. I am going to just go ahead and get a whole new fender and was going to see if you could come up with a "quick fix" just so the door opens...youll see how the fender was pushed down and dented just far enough and out of wack the door will not open on passanger side. We can discuss that on site to see if that is something you would recomend/be willing to do.
Again, I cant let you guys know how much I appreciate all the help through this! And, I look forward to doing business with you guys now and in the future. Also, feel free to email anytime guys with any info
dmccoy@hirsigfrazier.com
then I will email you back with contact number and so forth.
