Stock FJ: Front Recovery Attachment Points? - Toyota FJ Cruiser Forum
 2Likes
post #1 of 13 (permalink) Old 04-15-2010, 04:23 PM Thread Starter
Quoted: 0 Post(s)
I'm looking at stock photos, but can't see if there are attachment points for a recovery strap on the front of the vehicle.
Are there?
PeteCress is offline
post #2 of 13 (permalink) Old 04-15-2010, 04:26 PM
nlk125's Avatar
Quoted: 1 Post(s)
Re: Stock FJ: Front Recovery Attachment Points?
yes.
For those who "Get It", no explanation is necessary. For those who don't, no explanation is possible.
nlk125 is offline
post #3 of 13 (permalink) Old 04-15-2010, 04:40 PM
volhoo's Avatar
Quoted: 0 Post(s)
There are 2 large recovery point (loops) mounted onto the frame, one on each side.
You can see them here, just above the outside ends of the lower red skid plate.
http://farm4.static.flickr.com/3241/3011331757_53916c3e58_o.gif
Vince / volhoo
Happy trails...
My Build: - now with LINKS to all my OFF-ROAD ADVENTURES on the 1st post!
http://www.fjcruiserforums.com/forum...brigadier.html
FJ Crew:
https://www.facebook.com/pages/FJ-Crew/129320947238836
My Online Portfolio:
http://www.vincepetersondesign.com
volhoo is offline
post #4 of 13 (permalink) Old 04-15-2010, 05:38 PM
Swingshiftworker's Avatar
Quoted: 39 Post(s)
volhoo previously said: View Post
FWIW, I've been told that those loops are NOT designed for use as recovery points and that they are only intended to be used as trailer transport tie down anchors. Not sure if this is true or not, but I personally would not rely on them to support the weight of the vehicle in a recovery situation.
Marty
2008 Black Sapphire Metallic BMW 335i
2007 VooDoo Blue Toyota FJ Cruiser 6MT - Bought 04/11/14
2007 Titanium Metallic Toyota FJ Cruiser AT - SOLD 9/9/11
2002 Island Blue Ford F250 4x4 7.3L TD SC LB Lariat
Swingshiftworker is offline
post #5 of 13 (permalink) Old 04-15-2010, 05:47 PM
Clemson FJ's Avatar
Quoted: 0 Post(s)
OP - yep. 2.
Swingshiftworker previously said: View Post
FWIW, I've been told that those loops are NOT designed for use as recovery points and that they are only intended to be used as trailer transport tie down anchors. Not sure if this is true or not, but I personally would not reply on them to support the weight of the vehicle in a recovery situation.
Never heard that... I've yanked my truck out of some serious mud with those 2 stock recovery points, as well as the one on the rear. Also used them when I was the one doing the pulling, several times on bigger trucks. Never an issue.
Craig
2007 FJC. 4x4 AT. Rear locker. Toytec Ulti 3" kit. Light Racing UCAs. Spidertrax 1.25". Body Mount Chop. 295/75/16 Hankook DynaPro MT. 16x8 ProComp Series 152. Trail Gear Rock Sliders. Custom Demello 3 hoop. Super 44. K&N Filter.
Rom. 1:16 "I am not ashamed of the gospel, because it is the power of God for the salvation of everyone who believes."
Clemson FJ is offline
post #6 of 13 (permalink) Old 04-16-2010, 04:23 PM
RogueLeader's Avatar
Quoted: 0 Post(s)
Send a message via AIM to RogueLeader Send a message via Yahoo to RogueLeader
As far as other vehicles go, you are right. However, the FJC uses those tie-down points as recovery points as well. They are a whole lot stronger than those on other vehicles. If you don't think so, go look at the front end of a Tacoma. If the Taco is an SR-5, or TRD Sport, you will see how the attachment points (left side) are not as strong. However, the TRD Off-Road does come with a heavy recovery hook on the right side.
Kraemer likes this.
USAF (Retired) 1971-1991
2010 SR5 Tacoma Double Cab TRD Off-Road, Magnetic Gray Metallic, V-6/AT
RogueLeader is offline
post #7 of 13 (permalink) Old 04-16-2010, 06:10 PM
Quoted: 39 Post(s)
RogueLeader previously said: View Post
Ok, thanks for the info. Guess I was misinformed.
I don't need to use those points anyway, because I've got an M8000 Warn winch, as well as D-rings and shackles on my Lucrum mount up front, but it's good to know in case I need to use them instead.
Marty
post #8 of 13 (permalink) Old 04-22-2010, 10:16 PM
volhoo's Avatar
Quoted: 0 Post(s)
If you have a choice, I would recommend using the frame mounted recovery points over the Winch, or the D-shackles on the Lucrum mount to pull or yank from.
Sometimes, depending on the situation, the factory frame mounted recovery points are hard to access (under a lot of mud / water etc...), and only then would I consider using the winch or bumper mounted D-shackles to pull (or yank) out my vehicle.
Hopefully I would NEVER have to YANK my rig out from the winch (I have the same winch btw and it has saved my rig at least twice).
JMHO.
Vince / volhoo
Happy trails...
FJ Crew:
volhoo is offline
post #9 of 13 (permalink) Old 04-23-2010, 08:20 AM
Quoted: 0 Post(s)
PeteCress previously said: View Post
Are there?
I thought the FJ was designed to not get stuck
08 Sandstorm Off-Road Package. No Mods, No Dirt, No Mud, No scrapes, scuffs, dents or dings. No windshield chips or cracks either.....But there's always time
newcruiseruser is offline
post #10 of 13 (permalink) Old 04-23-2010, 08:41 AM
NCFJ's Avatar
Quoted: 4 Post(s)
The tie down/recovery points on the front of the FJ are pretty stout items. They are 15mm (1/2") solid steel hoops. They are mounted at the bottom of the frame through two verticle plates, welded to both of those plates and also the bottom of the frame horn. They are not going anywhere.
Pulling from that point on the frame also has advantages of using any bumper mounted recovery points. First and formost there is no leverage being applied to the rig via a bumper. Second is that the recovery point on the bumper relies on the surrounding material as well along with how it is attached to the frame.
All in all I can say that I have used my front recovery points for everything from recoveries where it was an anchor point to a tree while using the winch in the rear, attachment point for the winch line when using a block, and tie down point when it is trailered. No bends , cracks, or deformation in the frame horn.
Kraemer likes this.
"The next best thing to playing and winning, is playing and losing"
Religion is for those who are afraid of going to Hell
Spirituality is for those who have been there.
NCFJ is offline
Human Verification
