Bucking In 4WD - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 11-27-2012, 01:39 PM   #1 (permalink)
Member Number: 62413
Bucking In 4WD
I've got a 2006 automatic transmission FJ. In 4 WD, when I'm reversing or moving forward without stepping on the gas the truck lurches or bucks gently. Usually happens in the parking lot. When I'm on the road, no problem. Can anyone figure it out? Thanks.
base camp is offline
Old 11-27-2012, 02:04 PM   #2 (permalink)
FredtheFJ's Avatar
Member Number: 58369
Re: Bucking In 4WD
There's no such thing as a 2006 Fj....
But also why do u have it on in a parking lot? You shouldn't have it on 4 wheel unless ur on dirt or loose gravle it will mess up your 4x4
2007 Sun fusion!
Mods- Leveling kit, Oem Steelies, MPAC rear door rack and Straddle, Custom light bar with 4 KCs, NestahEdition CB radio antenna, Custom axe and shovel roof mounts. And Many Many more to come!!!!
^^Click for build thread!
-We rise, born in the flesh. I will not let this be my regret!-
FredtheFJ is offline
Old 11-27-2012, 02:06 PM   #3 (permalink)
FJX2000's Avatar
Member Number: 52569
Location: Cortez, Colorado (2 Hours away from both the FJ Summit and Moab)
Re: Bucking In 4WD
I think i'm having trouble understanding what "bucking" is. Is it like a sudden jump in speed without your foot on the pedal instead of a gradual increase in speed??
P.S.- your FJ may have been made on 06 but technically it's known as an 07 just FYI
FJX2000 - Hayden
2007 FJ Cruiser TRD Special Edition AT
See Ya At FJ Summit No.7 & Cruise Moab 2013!!!
Mods: 305/70R16 Fierce Attitudes, ReadyLIFT 3" Lift, Spidertrax, TRD Wheels, KC HiLiGhTs Slimlights, Rocktek Armor, Bushwackers, Blacked Out, LEDs all around, DDM Tuning 8000K HIDs, Light Racing UCAs, and so much more!!!
Go to my GARAGE or click here to see the STORM DAMAGE TRD build thread!
Or check out this thread to see all my FJ's Off-Road Adventures!!!
FJX2000 is offline
Old 11-27-2012, 02:17 PM   #4 (permalink)
Re: Bucking In 4WD
Hayden, with the foot off the accelerator (at very low speed) the truck moves in short lurches.
Old 11-27-2012, 02:21 PM   #5 (permalink)
stringmachine's Avatar
Member Number: 7766
Re: Bucking In 4WD
Really, I thought they were supposed to be bucking since they are so Awesome!
Really, When you are in 4WD and 4L be off road, and in this position it is not a normal driving vehicle. but care, safe gas pedal levels and finesse is the key . this thing has a lot of torque in this range. not a hot rod or something you want to be racing around in. let the gears do the work and help control the vehicle. (Slow) and easy is the key..
"Why do you carry a 45?". The Ranger responded with, "Because they don't make a .46."
stringmachine is offline
Old 11-27-2012, 03:51 PM   #6 (permalink)
FJX2000's Avatar
Re: Bucking In 4WD
base camp previously said: View Post
Hmmm... that is interesting. But what Fred says does make me wonder. Do you drive around on dry pavement in 4wd often? Because in the vehicle manual it strongly advises against driving in 4WD on hard surfaces, it could mess stuff up and is not good for the car. Or are you just driving in a straight line on the pavement in 4WD just to test it out?
FJX2000 - Hayden
FJX2000 is offline
Old 11-27-2012, 03:58 PM   #7 (permalink)
Member Number: 58129
Re: Bucking In 4WD
My manual recommends putting it 4wd at least once a month to lubricate parts but it's specific about only driving in a straight line on hard pavement.
tanyasparky75 is offline
Old 11-27-2012, 04:07 PM   #8 (permalink)
jasonfjc's Avatar
Member Number: 60288
Re: Bucking In 4WD
do not use 4WD on hard surface unless you are going absolutely straight.
whats causing the "bucking" is tires getting dragged across the surface due to locked front and rear diffs trying to turn at different speed.
its called binding.
The past is past, focus on the present, and paticipate the future.
2013 Toyota FJ Cruiser
2009 Mazda RX-8 R3
2008 Yamaha YZF-R6
jasonfjc is offline
Old 11-27-2012, 05:27 PM   #9 (permalink)
Winterpeg's Avatar
Member Number: 18294
Re: Bucking In 4WD
jasonfjc previously said: View Post
its called binding.
x2
Driveline bind. This happens when you are turning. The outside wheel has to travel a greater distance than the inside tire. This causes the bucking.
It shouldn't explode but the above advice about being on a surface where your wheels can slip a bit is a good rule of thumb.
Suck it up... it's only -40
2008 FJ Trail Teams
ARB Front Bumper; Apex rocksliders; 2x IPF lights on bumper; ARB Full Roof Rack W/ Grid; ; Old Man Emu suspension; magnaflow muffler (mashed the original); Warn M9000 winch; 48" hi-lift extreme jack; 285/75/16 Duratracs; Ricochet skids, full set HD, black anodized; Uniden PC78 Elite CB (ch 8 typically, ch 19 on the hwy)
Excellent parts source:TRDParts4U
Winterpeg is offline
Old 11-27-2012, 06:02 PM   #10 (permalink)
Re: Bucking In 4WD
Hayden,
No, I don't ride on dry pavement in 4wd. Today I was on asphalt, but it was slushy, icy and I had it on H4. (manual says "use H4 for normal driving on wet, icy or snow-covered roads") Didn't switch back to 2wd before going into the garage, because I needed the traction to get up the ramp.
