Just bought the '14 TT and love it! Would like to place oval convex mirrors on the FJ but have read different thoughts on the best place to mount them--inside corner or upper outside corner.
I have mine on the upper outside. They are the 2" version. For me "personally" i felt the lower inside was to low down on the mirror. I prefer the view with them up higher on the mirror.....just my 2 cents, to each his own...
SG,
I agree with you on the placement, upper outside.
I also have the adjustable round mirrors which give you a better range or field of vision.
My $.02!!…..gm
I have mine on the upper outside too. It just makes sense to me to have them there to cover the blind spot. They really help and have saved my bacon several times while doing lane changes in the city.
You want them as far out as possible. I would have liked to put it on the lower side of the mirror, but with the way the mirror has that corner cutout, I just put it at the top corner like everyone else. I also bought the adjustable ones so I can point them lower to the point where I can see my rear tires touching the ground. I'm sure that will come in handy off road.
Has anyone used the rectangular ones? I was thinking about these in the lower section of the mirror, but after reading the above, it makes sense to have them in the upper outside section.
This is what I had done as well, but I recently ended up removing them because I found that by spending some time getting my mirrors properly adjusted I didn't need to use the convex ones at all.
Guess I'm in the minority, got mine on the lower outside. Someone had them there on my '07 when I bought it, so I put them in the same place when I got my '11.
I'm the total odd ball here.. mine are on the lower inside. I recommend sitting in the car and having a second person hold them in different spots while you are in your normal driving position. That's what I did. I'm sure everyone is different.
ENHANCE YOUR DRIVING "No more blind spots! These mirrors are perfect. A must have." @freedomchariot Drive safely without blind spots When was the last time you almost hit a car because you didn't see the car in your blind spot? Suma Performance mirrors are full convex mirrors reducing your...
www.sumaperformance.com
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.7K members
Since 2005
