Old 08-28-2007, 03:31 AM   #1 (permalink)
use2b's Avatar
Member Number: 13289
how can i program new remote ?
My FJ had 6200 miles on it when i bought it and both remotes were missing.
I bought an 07/fj remote off ebay and would rather not deal with the dealer on getting it to work.
does anyone know how to program it for my FJ ?
Thanks
use2b is offline
Old 08-28-2007, 07:13 AM   #2 (permalink)
Buckwheat's Avatar
Member Number: 9970
Re: how can i program new remote ?
Here is the procedure. I've not used it but it is supposedly from the repair manuals. Please post here if it works (or not).
REGISTER RECOGNITION CODE MANUAL OPERATION
(a) Check that the following conditions are met No key is in the ignition key cylinder.
Only driver side door is open
(b) Insert the key into the ignition key cylinder, and remove it twice within 5 seconds
(c) Perform the following operations within 40 seconds Close and open the driver side door twice.
Insert the key into the ignition key cylinder, then remove it.
(d) Perform the following operations within 40 seconds Close and open the driver side door twice.
Insert the key into the ignition key cylinder, and close all doors.
(e) Perform the following operations within 40 seconds Turn the ignition switch from LOCK to ON and back to LOCK 1 to 5 times at approximately 1 second intervals to select a mode (see table below).
I'll try to reproduce the table the best I can.
Number of ON-LOCK operations of ignition switch:
[Add Mode]: ON-LOCK operation - Once (use this to add a new remote) [Rewrite Mode]: ON-LOCK operation - Twice (use this mode for completely rewriting all registration codes (e.g. you lost a FOB)) [Confirmation Mode]: ON-LOCK operation - 3 times (use this to confirm the number remotes currently configured to your FJ) [Prohibition Mode]: ON-LOCK operation - 5 times (I'm not sure what this mode
does)
HINT:
If the number of ignition switch ON-LOCK operations is 0, 4, 6, or more, there will be no response (power DOOR LOCK and UNLOCK operation) to show which mode has been selected.
Remove the key from the ignition key cylinder.
(f) The main body ECU automatically performs power door LOCK-UNLOCK operations to indicate which mode has been selected.
Response to mode selection (Power door lock operation):
[Add Mode]: LOCK-UNLOCK operation - Once [Rewrite Mode]: LOCK-UNLOCK operation - Twice [Confirmation Mode]: LOCK-UNLOCK operation: The number of registered codes
(1 - 5 times)
[Prohibition Mode]: LOCK-UNLOCK operation - 5 times
HINT:
In Confirmation Mode, LOCK-UNLOCK operation will occur once for each recognition code that has been registered. For example, if 2 recognition codes have been registered, the LOCK-UNLOCK operation will occur twice.
In Confirmation Mode, if no recognition codes have been registered, LOCK-UNLOCK operation will occur 11 times.
If Confirmation Mode or Prohibition Mode is selected, the operation ends after the response to the selected mode is completed.
(g) Register a new recognition code (Add Mode or Rewrite Mode) in accordance with the following procedure.
Within 40 seconds of Add Mode or Rewrite Mode being selected, press the LOCK and UNLOCK switches on the transmitter (keyless remote) switch simultaneously fo 1.0 to 1.5 seconds. Within 3 seconds of moving your fingers away from the switches, press either switch of the transmitter for more than 1.0 second.
Within 3 seconds of the transmitter switch being released, the LOCK-UNLOCK operation will be automatically performed once if the registration of the recognition code is correctly completed. (if not wash and repeat)
HINT: If the LOCK-UNLOCK operation is performed twice, the registration of the recognition code has failed, so perform the registration procedure from the beginning once again (bummer).
(h) If multiple transmitters need to be registered, repeat the registration of a new recognition code procedure within 40 seconds of the previous registration.
(i) If any of the following conditions are met, the Registration Mode will
end:
The key is inserted into the ignition key cylinder.
Any doors are opened.
40 seconds or more elapse after code registration.
(j) Registration of recognition codes (Add Mode and Rewrite Mode) is completed.
Buckwheat is offline
Old 08-28-2007, 07:22 AM   #3 (permalink)
wesayso's Avatar
Member Number: 5111
Holy Crap!
Grok FJ
NON supporting member
But do not worship it,
For it shall pass.
H. L. Mencken
Wesayso's mod up
'77 FJ40
'89 4Runner
'90 4Runner
'89 4Runner #2
wesayso is offline
Old 08-28-2007, 03:46 PM   #4 (permalink)
use2b's Avatar
Thanks very much buckwheat . My remote should arrive any day now and i will give this a shot.
40 seconds ?, Now i wish i wouldn't have killed all those brain cells in my youth!
use2b is offline
Old 08-28-2007, 07:45 PM   #5 (permalink)
slimer's Avatar
Member Number: 1985
Send a message via AIM to slimer
I love how they make you look like an idiot if you want to do something yourself. use2b, make sure you get a video.
slimer is offline
Old 08-28-2007, 07:50 PM   #6 (permalink)
Mtbcoach's Avatar
Member Number: 2433
I'll be interested to see if it works. Not that I doubt the information, just that you can't even change the programming of the locking feature without going through the dealer. Let us know how it works...
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper SSR 35 X 10.5
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
Mtbcoach is online now
Old 08-28-2007, 09:55 PM   #7 (permalink)
GoISU's Avatar
Member Number: 9211
That is one crazy procedure! I couldn't even handle the steps to cancel the seatbelt reminder chames!
GO REDBIRDS!
2007 BD FJC, AKA:SHERPA
*285-70-17 Firestone Destination M/T's (thanks Cred)
*All Phase Diff Armor
TLCA#17671
T.O.G.A. MEMBER?
FJ Summiteer 2008...First group over Black Bear in the 2008 Ouray FJ Summit
GoISU is offline
