Old 05-05-2006, 08:25 AM   #1 (permalink)
Member Number: 1511
If you have a driver side door rattle or squeek, listen up....
I had a rattle that was driving me crazy! It sounded like it was coming from right behind my head, like from the rear door or maybe from the column that houses the seatbelt. I took it to the dealer and the heard it, but wanted the car for a few hours to do some testing. I envisioned them "testing" my vehicle by driving it around.... no thanks.
I went home. I had concluded that I could make it stop by applying pressure to the door panel. I was prepared to take the door panel off to see what I could find. Upon examination, I noticed that there is a plastic piece in the door jam, just below the metal "U" bolt that the door locks into when it closes. I'm not sure what this little plastic piece does, but it floats in and out, depending on whether the door is open or not. Check it out, it is very loose. I jammed a piece of paper in, underneath it, and the noise has disappeared. So, I found the problem. Now I just need to find a more permanent fix. Hope this helps anyone with the "door rattle problem".
joecruiser is offline
Old 05-05-2006, 12:37 PM   #2 (permalink)
Not Serious
MissFJ's Avatar
Member Number: 1937
Re: If you have a driver side door rattle or squeek, listen up....
Thank you for the info! Mine only rattles when wheeling or on rough roads, but if this is the cause, it will worry me less.
MissFJ is offline
Old 05-05-2006, 04:45 PM   #3 (permalink)
B!tchMonkey's Avatar
Member Number: 1126
After driving a D1 Disco for years I feel like I am encased in some broad's uterus it's so quiet....
'07 FJ loaded, in Black nothing aftermarket (yet) bought 3/24 @ MSRP-SB Toyota rocks!
'04 Aprilia RSV Tuono R-Wheelie machine. Scares me except I am always giggling uncontrollably.
'01 Honda XR650R- Racetech suspension *splooge*. Climbs trees. Hasn't killed me yet, check back often.
'98 Seadoo XP Limited - Wave jumping whore.
'98 Seadoo GTX-Water caddie for the lake tramps.
'83 Brougham Class C- SOLD - Toyhauler time!
'95 Disco SOLD - B!tch you've been replaced!
B!tchMonkey is offline
Old 05-05-2006, 05:11 PM   #4 (permalink)
cheazhd's Avatar
Member Number: 56
What? Did somebody say something?
I've got Wrangler Ear....
CHEAZHD
Member since September 2005
cheazhd is offline
Old 05-05-2006, 05:18 PM   #5 (permalink)
fjarch's Avatar
Member Number: 1809
Joe, is this something the dealer would fix for free. I suppose warranty covers it. Im not a very handy person and so I would like to have somebody fix it and I figured Toyota should do it. I have the same problems. I thougth it was the folding back seats. It's annoying...
fjarch is offline
Old 05-05-2006, 05:24 PM   #6 (permalink)
FJCharlotte's Avatar
Member Number: 871
wow...somebody else to join the sick puppy humor club...
This is why I Fight: http://www.youtube.com/watch?v=RDfggrz5uF4
Bringin' the Tots back by popular demand
07 FJC Voodizzle, A/T, 4x4, Conv. Pkg., Up 2, TRD Exaust, 17" BBS Wheels w/BFG A/T's, Extended Middle Finger
FJCharlotte is offline
Old 05-05-2006, 06:22 PM   #7 (permalink)
Everything In Moderation
Landrover's Avatar
Member Number: 772
The only thing I could hear in my Disco was the howling of the Goodyear MT/R's.....probably because of a lack of a CD player as it was on the fritz. I was unlucky enough to have the Pioneer changer before they changed to the Alpine made unit. Other than that my Disco was tight, and at 197K I didn't think that was too bad.
Landrover is offline
Old 01-11-2008, 06:31 PM   #8 (permalink)
Member Number: 16516
you wouldn't happen to have any photos of this plastic piece would you?
fjdave5341 is online now
Old 01-11-2008, 06:42 PM   #9 (permalink)
chichid65's Avatar
Member Number: 15447
joecruiser previously said: View Post
I went home. I had concluded that I could make it stop by applying pressure to the door panel. I was prepared to take the door panel off to see what I could find. Upon examination, I noticed that there is a plastic piece in the door jam, just below the metal "U" bolt that the door locks into when it closes. I'm not sure what this little plastic piece does, but it floats in nd out, depending on whether the door is open or not. Check it out, it is very loose. I jammed a piece of paper in, underneath it, and the noise has disappeared. So, I found the problem. Now I just need to find a more permanent fix. Hope this helps anyone with the "door rattle problem".
Man, I have complained about this from day one, nobody knows how to fix it. it's driving me nuts I have to turn my stereo on just so I won't hear it.
I will def. try this out and if it works come on over to my neck of the woods for a steak dinner!!!
"A Year Of Change"
2008 FJ-VooDoo blue/4x4/AT/GPS/K&N Air Filter/Revos/Up Pkg.2/VIP RS3200 Plus Security System/OEM Roof Rack/OEM Rock Rails/Tow Package/All Weather Floor Mats & Rear cargo Mat//Recovery strap.
chichid65 is offline
Old 01-11-2008, 07:18 PM   #10 (permalink)
FJShocK's Avatar
Member Number: 16247
I have a small rattle in the area of my driver side doors too. I was guessing that it may be in the seatbelt mechanism, but I'll check the plastic thing you are talking about.
FJShocK is offline
