Old 10-17-2007, 02:28 PM   #1
Super Moderator
Fjamming's Avatar
Member Number: 6623
Machining experts please advice.
When working with aluminum, is it possible to receive a product that has a 1/8th inch variance? Is that acceptable? How does aluminum arrive? Blocks? I don't know how you receive and work with aluminum, but I received a product recently that's out of spec by 1/8 of an inch. They were rings that was suppose to be at 5/8th inch thick, but came in at 1/2 inch. The vendor told me when they received the raw material, sometimes there's a variance. The item was CNC machined and I thought it's suppose to be very precise. 1/8th of an inch sounds ridiculous. Am I wrong?
Thanks.
Sandoo Blue FJ
Walker Evans 2.5 dia. front shocks, adj. rear reservoir shocks, Pro Links. AP F&R bumpers, AP 1.25" UCA, Demello skid, TMax 9000 Competition winch. Viking Trail Line. 34X10.5X16 Swamper LTB. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240 HID, All Pro Swing Out, .
SoCal Events Calendar
Last edited by Fjamming : 10-17-2007 at 03:15 PM. Reason: additional content added in italics
Fjamming is offline
Old 10-17-2007, 02:59 PM   #2
Briman42487's Avatar
Member Number: 7204
Re: Machining experts please advice.
what is it? if they used a good raw material and a cnc, it should be perfect. chances are they either had a bad batch of materials or something was wrong in the computer.
Briman42487 is offline
Old 10-17-2007, 03:02 PM   #3
Super Moderator
Fjamming's Avatar
Member Number: 6623
Suppose to be "highest quality aircraft grade aluminum available".
Sandoo Blue FJ
Fjamming is offline
Old 10-17-2007, 03:06 PM   #4
mikey's Avatar
Member Number: 2806
Was it a finished product or raw material.
A CNC is only as good as the program, might be that they have 'loose' tolerances.
Hug a logger and you'll never hug another tree.
mikey is offline
Old 10-17-2007, 03:07 PM   #5
Super Moderator
Fjamming's Avatar
Member Number: 6623
It's beadlock rings. I imagine they had to use raw materials and machine it to the rings I wanted.
Sandoo Blue FJ
Fjamming is offline
Old 10-17-2007, 03:13 PM   #6
mikey's Avatar
Member Number: 2806
I see, I thought maybe you had received some raw material you wanted to machine.
Which dimension is out of spec on the ring?
mikey is offline
Old 10-17-2007, 03:14 PM   #7
Super Moderator
Fjamming's Avatar
Member Number: 6623
They were suppose to be 5/8th inch thick, but came at 1/2 inch.
I added additional content to the original post to make it more clear. Added text in italics.
Sandoo Blue FJ
Fjamming is offline
Old 10-17-2007, 03:17 PM   #8
NCFJ's Avatar
Member Number: 8585
1/8" is not acceptable. The whole premise that the raw material was off is not a valid claim. The CNC machining process is based on cutting a specific piece from raw material no matter how big the raw material is. Obviously you cant cut a 5" piece from 4" of raw material, but you can cut a 5" piece from a 6",7",20".30" you get the idea. I would not accept a piece that I was paying machining cost on to be 1/8" out. Heck, you can stamp bead lock rings out to better tolerances than 1/8"
NCFJ is offline
Old 10-17-2007, 03:18 PM   #9
Member Number: 7204
so its a 1/2" the whole way around. someone just entered the wrong numbers.
Old 10-17-2007, 03:19 PM   #10
Super Moderator
Fjamming's Avatar
Member Number: 6623
Briman, it's 1/8th inch thinner then it should be. Not sure if they entered the wrong numbers or just trying to save some money.
Sandoo Blue FJ
Fjamming is offline
