Re: MP3 help!
itunes doesn't suck -- the problem is the files you have are probably .AAC files and not MP3 files.
This is because this is the default file format iTunes uses when importing songs from CD (it sounds better than MP3 with smaller file sizes)
To fix this, go to preferences, under "advanced" click on "encoding" -- change from AAC to MP3 (there are 3 quality settings)
Then once you have done that, you can select all your music (as long as it wasn't bought from itunes) and then click "advanced" and then click "convert to MP3" -- works like a charm, did it the other day to make an MP3 CD for my FJ.
NOTE: while it is converting your songs, do not unselect the songs this way, when you are done you can press "apple+delete" and it will delete only your previously selected AAC files -- that way you won't have duplicates of both AAC and MP3.
Plus... I think this is probably a little more helpful than "itunes sucks use limewire" if you have a lot of music that you don't feel like downloading again.
4X4 MT CG UP Black.
