Old 02-27-2008, 05:37 AM   #1 (permalink)
Member Number: 11899
Need Help on Jack Stands
I have two two ton jack stands. I am gonna put one on each side of the frame and do work. Most people on the threads recommend three ton. WIll this work? The fj wieghs 4400 lbs. So mathematically i am well covered. Two jaack stands should support 8000 lbs or more. Let the help begin. Thanks in advance. Oh yeah, the two jacks will be used only in the front. the rear will still be on the ground.
belabano is offline
Old 02-27-2008, 05:46 AM   #2 (permalink)
1911's Avatar
Member Number: 4994
Re: Need Help on Jack Stands
You will be fine safety-wise. One advantage to higher-rated jack stands is that they are taller. The stock FJC is farther off the ground than most cars and after you lift it obviously it is more so.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
1911 is offline
Old 02-27-2008, 05:52 AM   #3 (permalink)
kokopelli's Avatar
Member Number: 16891
Location: I'm not like them, but i can pretend... cause my baby don't dance to nothing but Earnest Tubb<<<=8)
AS you have noted you have two, four thousand pound jack stands. People normally get as much jack and jack stand as they can, if they plan on working under there.
The issue is what are you going to be doing? If the wheels and tires are staying on and you're careful, everything should be fine. Personally I don't like to actually be under a vehicle with the wheels and tires removed. Too many people get crushed that way. Normally I'll hear of at least one person per year getting crushed. Some survive, some don't.
If I planned on being under there without the wheels and tires, I'd use the ones I have and buy another set and use those as well! Jack stands are cheap, funeral's aren't. Ron
belabano previously said: View Post
kokopelli is online now
Old 02-27-2008, 06:04 AM   #4 (permalink)
NCFJ's Avatar
Member Number: 8585
1911 previously said: View Post
X2, WHen it comes to jack stands I have always thought more is better as well. They are cheap so buying a second set is never a big deal
" "The next best thing to playing and winning, is playing and losing"
I live in typo hell, excuse the typos
Custom Steel fabrication-PM me
My FJ may be new, but this aint my first rodeo
My Front Tube Bumper
NCFJ is online now
Old 02-27-2008, 06:21 AM   #5 (permalink)
kokopelli's Avatar
Plus they last forever, if you get the real ones. I don't like those little steel "light weight" ones with the pins. Get the real "heavy" ones with the rack/lock. My current set of four 3-ton standa are 11 years old. Ron
NCFJ previously said: View Post
Old 02-27-2008, 06:24 AM   #6 (permalink)
Right on thanks guys. The wheels will remain on and another set sounds like the best approach. Thanks guys for quick feedback.
belabano is offline
Old 02-27-2008, 06:34 AM   #7 (permalink)
kokopelli's Avatar
That's the ticket.. If the wheels are on, just stay out from under them and don't put any body parts in-between anything else.. Ron
PS: Stacking a few 2X6's under the wheels doesn't hurt either!
Old 02-27-2008, 07:18 AM   #8 (permalink)
mattchooness's Avatar
Member Number: 17718
I know I might get flammed for this but Harbor Freight has a pair of 6 ton stands that are nice and tall for like $19 or something close to that. I used to have a Ford Expedition and those things worked great and that thing weight 5800lbs. The problem I have now is that my aluminum jack is not really tall enough and I have to use a block in order to get the stands under the FJC.
Matt
07 FJ Cruiser 4wd Automatic / Black Diamond
02 Suzuki SV650S / Blue
mattchooness is offline
Old 02-27-2008, 07:25 AM   #9 (permalink)
TCao's Avatar
Member Number: 940
You'll be fine with the 2-ton jackstands as long as they're tall enough. Don't forget to chock the wheels.
2007 Ti FJC
TCao is offline
Old 02-27-2008, 07:41 AM   #10 (permalink)
kokopelli's Avatar
They should be fine. You'll normally see the same jack stand's at many different places, just a different label.
That's the problem with a lit of jacks. I like to have at least a 19"-21" jack. The bigger/heavier truck jacks will go even higher, but they are not very portable. Ron
mattchooness previously said: View Post
Matt
