Old 04-06-2008, 04:51 PM   #1 (permalink)
Member Number: 4003
problem with exhaust bolt
I was trying to unbolt the two 14mm bolts on my stock exhaust so I could install the high clearance pipe. One bolt removed easily, but the head on the other bolt started to strip out in the socket. I've applied WD40 liberally, but am not sure I can get it removed. Any ideas?
LGraubner is offline
Old 04-06-2008, 07:50 PM   #2 (permalink)
Banned
Member Number: 18241
Re: problem with exhaust bolt
Go buy some high quality drill bits and drill that sucker out.
F.E.A.R. is offline
Old 04-06-2008, 08:30 PM   #3 (permalink)
Chrs's Avatar
Member Number: 5074
Send a message via AIM to Chrs Send a message via MSN to Chrs Send a message via Yahoo to Chrs
I believe some members have just sawed it off. I will probably find out when I installed a JBA exhaust.
2007 "Virgin" Shortbus - Passenger Armrest · 2008 Sun Visors · A-Trac Switch
Chrs is offline
Old 04-06-2008, 08:42 PM   #4 (permalink)
layonnn's Avatar
Member Number: 10006
LGraubner previously said: View Post
Sawing i don't think will help you as you are not installing a whole new exhaust, but just the high clearance one. I know exactly what two bolts you are talking about. PB lube (find at walmart) is much much better for this application. However, even after soaking mine for hours, they still wouldn't budge and broke a socket.
The drill bit idea would be good, i just think it would be near impossible to get to with out unbolting the whole exhaust system. Mine wouldn't come loose at all when installing new exhaust, so i just hacksawed the rear above the axle and pulled it out. This maybe an option though.
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is online now
Old 04-07-2008, 07:47 AM   #5 (permalink)
Nate's Avatar
Member Number: 15861
Layton, you mean you sawed the old exhaust, or the bolt? Do you reuse these bolts when putting on the JBA? *sigh* I really need to find the time to put mine on...
The great city of New Orleans--Where the schools never open, and the bars never close...
http://www.texasfishingforum.com
As my mother always said, "The more you bother me, the longer you'll wait..."
Nate is offline
Old 04-07-2008, 07:51 AM   #6 (permalink)
JoeUser's Avatar
Member Number: 15334
WD-40 is a lubricant, and not penetrating oil.
The absolute best penetrating oil I've ever used over the years is a K&W's Knock-er-Loose. You can probably find it at most auto parts stores. I've seen Knock-er-Loose penetrate what I thought was almost fused rusted parts... great stuff. It just takes time to do its thing...
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
JoeUser is offline
Old 04-07-2008, 07:54 AM   #7 (permalink)
Crotalus's Avatar
Member Number: 15654
For rounded-off bolt-heads, you might try these:
Irwin sockets for rounded-off bolt heads and nuts?
Hisssssssssssssssss!!!
-Crotalus
2007 Voodoo Blue 6 MT
Rear differential and locker scuba mod
A-Trac switch installed
Custom CB antenna mount
Custom tube bumper in the works...
Crotalus is offline
Old 04-07-2008, 08:24 AM   #8 (permalink)
Briman42487's Avatar
Member Number: 7204
if the bolt is garbage anyway, time to cut it. air saw, sawzall, torch....
Briman42487 is online now
Old 04-07-2008, 02:33 PM   #9 (permalink)
DEWFPO's Avatar
Member Number: 7505
Those special rounded off bolt sockets works well, but you can still heat the bolt good and hot, then let it cool to break it loose, then penetrant, then use the special socket. Or you could heat the area around the bolt (but not the bolt).
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 04-07-2008, 03:30 PM   #10 (permalink)
Member Number: 11817
Send a message via Yahoo to ziggzaggman
Make sure your using a quality SIX point socket. Otherthan the penetrating oil (PB Blast) break that sucker off and get you a new one.
ziggzaggman is offline
