My damn engine splash guards kept falling off. Hanging and flapping when i drove down the road. They are thin and might as well not even be there. I didnt know you could buy better after market engine splash guards and after a bit of research online I stumbled across this guy (rad rubber designs). I think I paid $50 for all 4 guards. They are 3 times thicker and they have way better clips too.. Just saying.. Figured I would give you guys a heads up in case you are having the same problem. I think he sells fender guards too and a couple other things. Rad Rubber Design : About
The fender flaps look cool. Could solve my left-hand turn lock issue without needing a full BMC.
"FJ FENDER FLAPS Front mud flap modification kit that increases up to 2" tire clearance and helps eliminate common tire scrape/rub from new tires. Will solve scrape/rub without BMC provided scrape/rub is minor usually driver's side while making hard left turn. If scrape/rub is more significant and hits body mount, then BMC is normally required and the FLAPS then provide a great cover up for the plastic area of the mud flap that must be cut away. The FLAPS are intended for those who wish to use their factory flares and mud flaps. Everything needed is included in the kit and the modification can be done in less than an hour on both sides."
they can be designed to fit as much or as little of the face of most lights(including enclosure) and work wonders at the problem of bug smear getting all into screws and vents ... they can also be colored (red,flat/gloss black, white, blue, pink,green)
My splash guards fell apart as well. I just ran across this and ordered some to replace whats left of mine. I was thinking about making them but this makes it too easy.
I'm wondering if the guy can do custom sizes for those of us with body lifts. The stock ones don't stretch and I've had a great view of the sides of my engine for awhile now...
Changed mine out yesterday, my old ones were brittle and falling apart. These are MUCH better quality and was a simple 15 minute install. Excellent product!
I'm changing mine out as they are falling apart
Went the cheap route for now and pulled them off and made templates and then bought at Walmart 4 black plastics file holders and cut them out and ready to install them
Cost me a grand total of $2.00 for the pocket folders
Keeps the water from splashing in... or at least slows it down a bit.
I also noticed the lack of them in my buddies Tacoma when we were wheeling through some snow for a bit.... his engine bay was caked with snow and mine was pretty bare.
Just got a set of these installed to replace mine which were falling apart at 120k. Very serious material and about a 15 minutes install. I expect them to last the life of the vehicle.
Just ordered a full set. Both fender and mudflap. Just went to 285/70/17s and have just a little bit of rubbing. Hopefully these mods will take care of it.
Talked to Eddie. It's nice to meet people that are passionate about their product.
Anybody have pics of the light bar covers or whatever they are?
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.6K members
Since 2005
