Re: If you are running 285/70/17 on your rig read this post!
Mine have never touched and have been worked off road pretty hard.
Also, as Layonn pointed out, regardless of the pressure, the sidewall bulge is on the lower half of the tire.
Finally, when the suspension compresses, the gap increases, although I guess there is potentially an issue when the suspension is at full droop, but I have never had an issue either way.
__________________ Rico's Rhino
'07 BD, AT, AllPro sliders, Hilift , fourtracks shovel mount and shovel, nuvi 660 GPS, ProClips for ipod and GPS, Cobra CB, Bandi mount, 4' firestick, EMU Heavy/Med suspension, Hella Black Magic driving lights on Defiant bar, 5 IPF lights on N-Fab roof bar, 3 pc. Allpro skids, AllPro pro links with skids, AFE CAI & TBS, BFG 285/70/17 M/T, TWM shift knobs, Wet Okole seat covers, AllPro rear bumper, AllPro high clearance exhaust, Lucrum Mount, M8000 w/synth line, gloomy bear
40k miles and never rubbed
i have had my rig in some pretty tight spots still no rubbing
OEM Rails- Midland CB with bandi mount antenna- BFG 285/70/17- DR 3" lift with body mounts trimmed -Total Chaos UCA's - All Pro High Clearance Tail pipe -All Pro 3 Piece Front Bumper With Large Light Bar - Hella, HELLA, HeLLa - Pioneer in dash NAVI- MOBIL 1 !!!
I couldn't get 285's to fit my current rims. They were less than a 1/2" from the UCA and when the wheel was turned they rubbed. Discount did a trial fit for me. That's why I am still running 265's. I think it is all about the offset of the rim.
I just got 285s for Mother's Day. I have not noticed any rubbing at all but I only put about 100 miles on them today.
Kim
Kim GO GameCOX!!! That is the original USC, BTW!!!
Pura Vida!!! Costa Rican for"Pure Life" live every minute of it!
The Cherry Garcia!!! '07 BC 4x2!!! Came home on August 10, 2006! Modded, trust me!! TLCA Member 18935
"New Orleans is the cradle of eccentrics. New Orleans is a gumbo, a melting pot of food, mood, mud and blood, where the Caribbean begins or ends, depending on your point of view." "Breathe in Breathe out, move on!!! Jimmy Buffet
thanks for all the replies.. i wasn't sure if in the future i would have a problem with them.
Congrats on your 285's Kim..
So if you do install spacers on the hubs, does this move the tire closer to the body mount? is seems like it could because without the spacer it is behind the mount more, and moving it out would put the tire in the middle of the mount? correct
I noticed the same thing and got to wondering about spacers as well. Then I went and jacked the wheel up all the way and then jacked the FJ up with one of the front tires at full droop. No rub at all either case, and it stays pretty considtent at about 1/2"-3/4" space. I had slight body mount rub at hard crank coming into driveways and such without a lift kit. Since the OME 3" I clear the mounts but think that wheel spacers will push it closer to the body mount. Everyone of the wheel spacer posts I have seen have been people running 1" or 1.25" spacers. You can get 1/4" or 1/2" spacers and maybe not rub on either area.
Mine rubs on the inside of the fenderwell sometimes.
But of course, I have been known to wheel pretty hard sometimes...
Still would not trade them.
--------------------------------------------------------------------------------- FJCruisersFlorida.com If everything seems under control, you're not going fast enough - Mario Andretti
From what I am reading, I would also think that just a 1/2 inch or so spacer should make you feel better, and still not rub.
I thought that 99% of the 285/70/17 were fine, but I guess I do have 16" so I could be wrong.
Need more money, for new truck!
This tire is only .900 larger in Dia / .450 in Rad
This tire is only .300 wider in section width / .150 from center of wheel
This isn't really enough to make any huge difference is it?
Size difference is neglible unless clearances are so tight from the factory and the Toyota designed geometry simply requires suspension modifications to accomodate this increase.
