Old 05-15-2008, 12:57 AM   #11 (permalink)
timbo2's Avatar
Member Number: 3828
Re: What the F***? -- Traction Control Gone?
Gas cap not seated.tighten gas cap, disconect battery, wait 30 min, reconect, done.
timbo2 is offline
Old 05-15-2008, 01:17 AM   #12 (permalink)
FJCcrawler's Avatar
Member Number: 19513
You might want to check the either the intake or the MAF censor cuz that happened to me and what happened was too much dust was blocking the MAF and all my lights on the dash lit up like a Christmas tree. Just clean the MAF and reinstall, and disconnect the battery to restart it.
FJCcrawler is offline
Old 05-15-2008, 01:31 AM   #13 (permalink)
Swingshiftworker's Avatar
Member Number: 11371
Thanks, EVERYONE! You guys have just paid for my "Life Supporting Membership."
I had previously opened and closed the gas cap, but did it again, and disconnected the battery to reset the ECU. Just waited a couple of minutes and everything went back to normal. I think the problem is probably gas tank/emissions related and is somehow connected to the installation of my MAF Auxillary Tank. If so, that's 2 emissions related problems w/the aux tank, so far. The other was vapor lock and engine stall if the aux tank is topped off. I have a locking cap on it now, which I never had any problems with before the aux tank was installed, but am going to put the OEM cap back on to see if that makes any difference.
Thanks, again. You guys rock!!!
Marty
Vote for Obama in 2008!
2007 Titanium Metallic Toyota FJ Cruiser (4x4 SUV)
2006 Mineral Gray Dodge Ram SRT10 Quad Cab
1999 Red Jeep Wrangler TJ Sport (4x4 Rockcrawler)
My Build Diary
Swingshiftworker is offline
Old 05-15-2008, 03:19 AM   #14 (permalink)
timbo2's Avatar
Member Number: 3828
Glad you got 'er worked out! Keep us posted if your cap change made a dif with the Man-a-Fre aux tank.
Keep on Truckin' Tim
timbo2 is offline
Old 05-15-2008, 11:44 AM   #15 (permalink)
mikerd400's Avatar
Member Number: 14094
Swingshiftworker previously said: View Post
I still use the locking gas cap, even after my warning lights went off. If the FJ has been sitting for more than a couple of days, I'll open the gas cap to let in vent, then put the cap back on. No problems since.
Mike
07 Ti Silver
mods: ARB bumper, Warn winch, OME lift, OME rear control arms, Body Armor rock sliders, Mickey Thompson Classic beadlock wheels, ProComp Xtreme M/T tires, MAF skid plate, baja light bar, All-Pro high clearance exhaust, Scuba Driver Mod
Mods by www.fao4wd.com
USMC 1988-1992, SEMPER FI
mikerd400 is offline
Old 05-15-2008, 11:56 AM   #16 (permalink)
FJ-Piper's Avatar
Member Number: 18567
Send a message via ICQ to FJ-Piper Send a message via MSN to FJ-Piper
Well now that's it'sfixed there is no point to offer my tried and true method to fix almost any problem on any vehicle.
1. Remove the gas cap, hold in place.
2. Drive a new vehicle under gas cap.
3. Replace old gas cap on new vehicle.
Your problem should now be fixed and hey, you didn't even have to change out THE WHOLE car!
Steven
KF6LYF
You can check out my TT rig here: <<Click Here!>>
FJ-Piper is offline
Old 05-15-2008, 12:06 PM   #17 (permalink)
Crotalus's Avatar
Member Number: 15654
FJ-Piper previously said: View Post
I heard that it was the radiator cap....
An FJ rolls on
hills muted by mountains pass
a true adventure
6 spd MT Voodoo Blue
Rear diff and e-locker scuba mod
CB w/ custom CB antenna mount on uppper rear door hinge
A-Trac switch installed
Custom tube bumper in the works...
Crotalus is offline
Old 05-23-2008, 03:05 AM   #18 (permalink)
timbo2 previously said: View Post
Nuts!
Got another check engine light today (w/the OEM cap this time) right after a tank refill -- both tanks full. Reset it by disconnecting the battery last time. Only hassle doing that is finding a place where I can turn in a circle to recalibrate the compass -- no parking lots near me, so I have to do it in an intersection. Going to carry a 10mm wrench from now on in order to reset the light on the road, if need be.
Can't remember the conditions when the tank came on the last time. I'll have remember to record the conditions here if the light comes on again to see if there's any apparent pattern.
Marty
My Build Diary
Old 05-23-2008, 12:00 PM   #19 (permalink)
UnionRef's Avatar
Member Number: 15138
FJCcrawler previously said: View Post
X2 - Also Uphill posted a thread about this very same thing and it was the MAF Sensor that needed to be cleaned. I cleaned mine right after I read his post. Good luck!
Tim
Tim
"Give blood...Play rugby"
UnionRef is offline
Old 05-23-2008, 08:34 PM   #20 (permalink)
UnionRef previously said: View Post
Tim
Thanks for reminding me about that. I'll check it out too.
Marty
My Build Diary
