Recovery points - Toyota FJ Cruiser Forum
 8Likes
  • 1 Post By Iconic_
  • 2 Post By bazross
  • 3 Post By Zero'sFJ
  • 2 Post By Papa Dragon
post #1 of 9 (permalink) Old 02-11-2017, 05:36 PM Thread Starter
mikey's Avatar
Quoted: 940 Post(s)
Recovery points
There has been a lot of discussion on recovery points both for factory and aftermarket bumper points.
Most of these have the inherent weakness of a pull on an angle. Has anyone thought of using something like this?
Crosby® HR-125W Hoist Rings to Web - The Crosby Group
Or am I missing some science behind this?
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #2 of 9 (permalink) Old 02-11-2017, 06:18 PM
Iconic_'s Avatar
Quoted: 1149 Post(s)
Re: Recovery points
I've looked at those lifting eyes. Not sure how the swivel mechanism will hold up under an FJ with dirt and such getting inside. Also there is the question of how it will be bolted to the FJC. Will it only use one of the existing rear M12 nuts? (not sure I like that) or how would you make a plate to go in-between so it uses the both of the rear frame nuts? Look at the rating if it only uses a single M12-1.75 nut to mount to. 1000 kg with a safety factor of 5 = ultimate breaking strength of 11,000 lbs, not a lot considering my strap breaks at 17.5k lbs. (rear nuts on FJC are M12-1.25 BTW so not sure if you could find one that works like that anyway)
So I would say a block needs to be machined so a larger one of these will work with both the factory rear bolts.
Another con is the price. They run pretty expensive. You would be paying for the CE certification and their load rating testing. The 3/4" Crosby linked below would still be questionable strength wise since for our use we would be ignoring the 5000 lbs WLL, it will break at 25,000 lbs. But over $400!
One of these side pull ones would be perfect. I really like it just has a hole for a shackle pin.
Crosby® HR-1200M Metric Side Pull Hoist Rings - The Crosby Group
Crosby 3/4"-10 x 1.65" HR-1200UNC Side Pull Hoist Ring - 5000 lbs WLL - #1067728
Unless anyone has any ideas, that's where I ended my search.
Not to say it can't be done, but that's just to follow my thought process.
Papa Dragon likes this.
Iconic_ is online now
post #3 of 9 (permalink) Old 02-11-2017, 07:04 PM
bazross's Avatar
Quoted: 1319 Post(s)
Re: Recovery points
G'day Mikey,
A good bridle is probably more beneficial than a Crosby for off road recovery
Just my perception.
Cheers
Baz
bazross is online now
post #4 of 9 (permalink) Old 02-12-2017, 06:29 AM
Papa Dragon's Avatar
Quoted: 99 Post(s)
Re: Recovery points
I had a moment when I saw the price. I pass on this mod unless it becomes a tried and tested main staple thought out the off road community.
I'm always amazed how much money you can drop into an off road vehicle. Its not uncommon for me to ride with people who have dropped over $20,000 into their vehicles. I'll freely admit I would love to spend $20,000+ on my FJ but retirement is 5 years away and I have a daughter who wants to go to Med school. (so retirement may not be 5 years away )
The chief end of man is to glorify God and enjoy him for ever.
爸爸龙
Papa Dragon is offline
post #5 of 9 (permalink) Old 02-12-2017, 07:52 AM
Mean Time Moderator
Zero'sFJ's Avatar
Quoted: 615 Post(s)
Re: Recovery points
Here in the UK Land Rover never fitted recovery points to the Defender (or earlier Land Rovers). All there was was lashing eyes (for strapping to the transporter)... Most people assumed they were for recovery but as they were just a flat plate they would bend and then snap. Using a bridle would make them usable if nothing else available but they needed to be replaced with mil spec JATE rings (Joint Air Transport Executive), (used for underslinging on a CH-47 etc)
These bolted through the same mount hole in the chassis and were able to 'swing' freely and could be loaded at any angle. Cheap to buy (except from Land Rover on an OE part number) and strong. I fitted them on my TLC but needed to space them as the LR frame turns out to be wider box.
Extreme 4x4 Ltd JATE RINGS
2014- FJC Cement "Eddystone" US spec personal import - mods in progress http://www.fjcruiserforums.com/forum...eddystone.html
Zero'sFJ is offline
post #6 of 9 (permalink) Old 02-12-2017, 11:24 AM
Quoted: 99 Post(s)
Re: Recovery points
Wonder if they ship to the US?
爸爸龙
post #7 of 9 (permalink) Old 03-20-2017, 08:10 AM
F Joy's Avatar
Quoted: 137 Post(s)
Re: Recovery points
i found these but they seem to be strictly for their own bumpers
Be careful when blindly following the masses ... generally the "m" is silent
Going to church doesn't make you a Christian anymore than standing in a garage makes you a car.
A Roaring Lion Kills No Game
F Joy is offline
post #8 of 9 (permalink) Old 03-20-2017, 08:16 AM
Mean Time Moderator
Zero'sFJ's Avatar
Quoted: 615 Post(s)
Re: Recovery points
Papa Dragon previously said: View Post
I can send them over if they don't
Zero'sFJ is offline
post #9 of 9 (permalink) Old 03-20-2017, 09:12 AM
Quoted: 99 Post(s)
Re: Recovery points
Zero'sFJ previously said: View Post
Thanks for the Kind offer Zero, I think the ones I'm getting from Iconic coupled with a soft shackle will do the trick.
Zero'sFJ and Iconic_ like this.
爸爸龙
Human Verification
