Old 05-28-2008, 09:39 AM   #1 (permalink)
CactusJK's Avatar
Member Number: 1157
Accessing holes Along Top of Drivers Side Under Hood
Is there a way to access the back side of the existing holes in the aft drivers side under the hood? I would like to put a bolt through an existing hole and be able to tighten it. It looks like you can remove the plastic trim cover along the side of the hood but not sure how to remove the clips.
CactusJK is offline
Old 05-29-2008, 09:25 AM   #2 (permalink)
CactusJK's Avatar
Member Number: 1157
Re: Accessing holes Along Top of Drivers Side Under Hood
Another way to ask this is how do you remove the plastic trim on either side of the hood access? When you do remove it can you access the holes on the sides?
CactusJK is offline
Old 05-29-2008, 10:07 AM   #3 (permalink)
JoeUser's Avatar
Member Number: 15334
I'm still in the dark as to where exactly you mean. Can you post a pic of the area, so everyone knows exactly the spot you're talking about?
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
JoeUser is offline
Old 05-29-2008, 10:16 AM   #4 (permalink)
wesayso's Avatar
Member Number: 5111
Whew, I thought someone was getting nasty.
Grok FJ
NON supporting member
But do not worship it,
For it shall pass.
H. L. Mencken
Wesayso's mod up
'77 FJ40
'89 4Runner
'90 4Runner
'89 4Runner #2
wesayso is offline
Old 05-29-2008, 05:53 PM   #5 (permalink)
CactusJK's Avatar
Member Number: 1157
I will when I get back from travel. Essentially this is the area right below the hood lift piston along the edge. Some people mount relays, etc along this edge. It is also the crumple zone where some people are experiencing cracks/bulging. There are a few existing holes there and if you can get behind them you can put a bolt througn without having to drill holes.
wesayso previously said: View Post
CactusJK is offline
Old 05-29-2008, 08:59 PM   #6 (permalink)
NDA431FJ's Avatar
Member Number: 10370
I think he is referring to this plastic which is the fender top cover.
It's easy to remove. Just 5 push out clips and 1 push in and pull out (near the hood shock). The plastic cover is also being held by ~ 3 white plastic clips on the other side. I removed this plastic when I run my 4 roof lights and I mounted the relays/fuse block (red) along this side of the engine bay. Let me browse my files of pictures if have some for the other side of the plastic.
2007 FJ Cruiser 4x4 Auto TI - Mods too long to list
2007 BMW 335i Black Sapphire - Twin Turbo
2000 Honda Odyssey EX - Navigation
1998 Toyota Sienna XLE - Supercharged
1989 Toyota Pickup - long bed
TLCA #17592
NDA431FJ is offline
Old 05-29-2008, 10:01 PM   #7 (permalink)
NDA431FJ's Avatar
More pictures:
The six clips removed:
Slowly, pull up the plastic cover starting from the front.
The three additional clips that holds the right side of the plastic cover.
TLCA #17592
NDA431FJ is offline
Old 05-29-2008, 10:14 PM   #8 (permalink)
bernd's Avatar
Member Number: 7688
x2 on the above ^^^
IT'S ALL GOOD!!!!!!!
bernd is online now
Old 05-29-2008, 10:51 PM   #9 (permalink)
CactusJK's Avatar
Member Number: 1157
That is exactly what I was looking for. Where did you get the FJ plaque on top of the fuse box?
NDA431FJ previously said: View Post
More pictures:
CactusJK is offline
Old 05-30-2008, 07:56 AM   #10 (permalink)
CactusJK's Avatar
Member Number: 1157
How do you remove the five push out clips? Are the three white clips pretty tough and break resistant? Any trick to releasing the white clips? Thanks for the great help and pictures!
CactusJK is offline
