Things I learned today - Toyota FJ Cruiser Forum
 129Likes
post #1 of 53 (permalink) Old 02-25-2017, 08:48 PM Thread Starter
mikey's Avatar
Quoted: 940 Post(s)
Some are new and some are refreshers:
Toyota's are a big Lego puzzle, just doesn't come apart like my mind thinks it should.
Panel clips, retainer clips are cheap.....unless you break a lot of them.
Heat shrink tubing will burn.
The tool I need at the moment is most inconveniently located.
Always find a tool in the last place I look which is never where I think I left it.
I'm not bendy.
Might have a touch of OCD
A dap of anti seize ends up everywhere.
A bolt dropped in the engine bay will go klink...klink....klink........but never clunk.
Pre measured wire is always to short.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #2 of 53 (permalink) Old 02-25-2017, 08:56 PM
scrufy's Avatar
Quoted: 24 Post(s)
Re: Things I learned today
I learned to pay attention to what your doing and you wont squirt out thread sealer everywhere you wanted to put Locktite Red. The tubes look almost the same.
13' Cement TT / Titanium Muffler Bearings
scrufy is online now
post #3 of 53 (permalink) Old 02-25-2017, 08:59 PM
Iconic_'s Avatar
Quoted: 1149 Post(s)
Always find a tool in the last place I look.
It's good to learn something new everyday! Here's one:
Isn't the tool ALWAYS in the last place you look? Or do you continue looking even after you've found it?
Iconic_ is offline
post #4 of 53 (permalink) Old 02-25-2017, 09:06 PM
rotorhed1's Avatar
Quoted: 330 Post(s)
I totally agree. 30 years as an aircraft mechanic taught me these things and more. When reaching into a tight space there will always be a cotter pin or safety wire to snag on.
You haven't lived until you hook a cotter pin under your skin and can't pull your arm out of said tight spot.
gaylonw, Zero'sFJ, scrufy and 2 others like this.
rotorhed1 is online now
post #5 of 53 (permalink) Old 02-25-2017, 09:30 PM Thread Starter
mikey's Avatar
Quoted: 940 Post(s)
Nah....the last I look is never where I think I left it.
gaylonw and scrufy like this.
Kermit the Frog
mikey is offline
post #6 of 53 (permalink) Old 02-25-2017, 11:31 PM
Bar3K's Avatar
Quoted: 1251 Post(s)
I'm not bendy.
I'm in with these two^^^^
Bar3K is online now
post #7 of 53 (permalink) Old 02-26-2017, 12:18 AM
tukes mountain man's Avatar
Quoted: 11 Post(s)
rotorhed1 previously said: View Post
I can relate. Started working on aircraft in 1970, still an A&P mechanic to this day. Still learning something new everyday.
2007 TRD SE
Mods: OME Med Lift, Tires 285/75/16 Nitto Trail Grappler M/T's, TRD CAI, Wilderness Rack with 4ea 130 watt 6" KC Slimlites, 2ea 130 watt 8" KC Slimlights mounted to front bumper, Cobra CB with Bandi Antenna Mount, Garmin 550 Street Pilot with Ram Mount. Scan Guage, Backup Cam.
Wish List: To much to list....
Tuke
tukes mountain man is offline
post #8 of 53 (permalink) Old 02-26-2017, 02:45 AM
Desert Moderator
amaclach's Avatar
Quoted: 1410 Post(s)
I can relate to most of those...
- Solder takes ages to melt, then you have a flash flood of molten metal everywhere. This is usually true when you are soldering something in place, and is directly proportional to:
a) how much skin will be caught in the torrent of molten solder
b) how much additional wiring / carpet / plastic will be coated in molten solder
c) the presence of a catch tray/splash guard.
gaylonw, Zero'sFJ and scrufy like this.
Black '14 6MT
Stock bumpers
Some mods
amaclach is offline
post #9 of 53 (permalink) Old 02-26-2017, 10:44 AM
Doc4216's Avatar
Quoted: 2 Post(s)
Something I have learned and re-learned: even though I think I have pre-staged all my necessary tools, I haven't.
For some reason, even though I know the oil is hot, I always underestimate how hot.
States my FJ has been to.
Doc4216 is offline
post #10 of 53 (permalink) Old 02-26-2017, 10:58 AM
CurbCrawler's Avatar
Quoted: 133 Post(s)
All above are good life's lessons including: Why you should where gloves when working with a punch and mallet!
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
Human Verification
