My extended rear travel (and a few other things) - install story - Toyota FJ Cruiser Forum
 63Likes
post #1 of 28 (permalink) Old 05-19-2017, 03:37 AM Thread Starter
debFJVT's Avatar
Quoted: 902 Post(s)
So it was an epic 2 days at Performance Unlimited in Woodstock VT. I love this garage - and how I get to be wrench in hand the whole time :-)
First up was the replacement 4.56 geared third member from ECGS which happily came with marking grease from their final test
Nice coverage of the teeth - compare with old diff - had entire clean sections indicating lack of contact between ring and pinion gears...apparently is VERY difficult to correctly install gears, and best left to experts
All fixed- no more whining!!
Next we popped the MetalTech dual rate coils and Radflo 2.5 long travel shocks in place. Really had to squeeze to get those long shocks in
And 2 1/2" bumpstops
Also RED extended brake lines lol
Very happy with droop!
Then problem with adjustable Toytec RUCAs - not enough space without hitting the gas tank. At full (straight) droop OE sat a mere 1/4" above the tank! Is my tank different? Bought her totally stock, and no one else seems to have had this issue.
Many ideas kicked around - reshaping the tank, lowering it - too dangerous... put OE RUCAs back on and started front limit straps, welding plates and clevis mounts to the frame beside shock towers
Then retired to my hotel - almost 9 straight hrs of work...exhausting!
To be continued......with a surprise ending!
Member of the Month November 2016
debFJVT is offline
post #2 of 28 (permalink) Old 05-19-2017, 04:23 AM
Joabmc's Avatar
Quoted: 357 Post(s)
Re: My extended rear travel (and a few other things) - install story
debFJVT likes this.
Joabmc is offline
post #3 of 28 (permalink) Old 05-19-2017, 04:41 AM
bazross's Avatar
Quoted: 1349 Post(s)
G'Day Deb,
looks great !!!!!
Well done....
Makes a huge difference, hey ?
Cheers
Baz
debFJVT likes this.
bazross is offline
post #4 of 28 (permalink) Old 05-19-2017, 05:24 AM
pierceg's Avatar
Quoted: 184 Post(s)
Interesting that the tank hits the upper ca.
Looking forward to seeing/reading the fix.
debFJVT likes this.
pierceg is offline
post #5 of 28 (permalink) Old 05-19-2017, 05:36 AM
StrangerRanger's Avatar
Quoted: 292 Post(s)
I've got the identical rear setup, minus the brake lines... still working that issue out. You'll love it.
Curious to see if you get the same coil slap that I do.
debFJVT likes this.
'07 Voodoo 4x4 AT
The Big Blue Build thread
StrangerRanger is offline
post #6 of 28 (permalink) Old 05-19-2017, 06:10 AM Thread Starter
debFJVT's Avatar
Quoted: 902 Post(s)
Next morning @bazross had suggested some cool Aussie offset RUCAs (Superior Engineering - made specifically for gas tank clearance lol) and was getting ready to order...
Then Rodney, the shop owner arrived, took one look at the problem and suggested a brilliant, simple fix, something he was currently using on his jeep ...
A limit strap on center of axle! At full STRAIGHT droop the ruca is at its closest to the tank but with articulation distance increases. A centered strap also does not inhibit articulation as it just pivots. So Rodney had his Jeep pulled in, harvested the strap and gave it to me - I was blown away!
A little cutting and welding and it was on, performing exactly as hoped :-) So my red RUCAs went in and just barely kiss the tank but all ok
But noticed the different angles they sit at and it's clear my track bar is too short - it's pulling everything to the side. Got a Rokman adjustable - thanks @svoruz !
On to the next part!
bazross, Zero'sFJ, Joabmc and 5 others like this.
debFJVT is offline
post #7 of 28 (permalink) Old 05-19-2017, 06:58 AM
Cholerabob's Avatar
Quoted: 145 Post(s)
I had RUCA but took them out and put the originals back in. They are a pain in the A** to grease ( gas tank side is impossible to do ), i never heard of anyone bending those, and it was always seizing because of our nice northern climat and roads , love Johnny joints...( changed it 2 times ) I also have that drop difference on the passenger side, on a lift the passenger side drops about 5 inchs more, i just live with it. Check how your rear bump stops hit, mine don't really do anything and i have to figure out why, they are installed properly but i end up stuffing my rear wheels so much in, that it jams, maybe my wheels are too big ? Nah... lol
debFJVT likes this.
OME lift Kit, Metal Tech Rear Long Travel, Camburgs Balljoint UCAs, Full Ricochet Skid Plates, All Pro Sliders, Metal Tech Offset LCAs , Luna Dual Battery, Cooper STT PRo 35s on 16' Mickey Thompson Classic Baja Locks, FJToyman Shock Skids, Total Chaos lower link Skids, Boztec Dif Skid, Exp1 front Diamond Bumper, Exp1 Rear Bumper with Carrier, Viper winch, Ricochet Lighted Air Dam
Cholerabob is offline
post #8 of 28 (permalink) Old 05-19-2017, 08:11 AM Thread Starter
debFJVT's Avatar
Quoted: 902 Post(s)
StrangerRanger previously said: View Post
You mean yours hit the gas tank too?
Haven't heard slaps but then I'm taking it easy while new gears are getting broken in lol
debFJVT is offline
post #9 of 28 (permalink) Old 05-19-2017, 08:30 AM
Quoted: 55 Post(s)
Looks good debFJVT!
I am curious to get your thoughts on the Radflo 2.5's in the rear. They are a great performance shock to compliment the removal of the sway bar but I feel mine are slightly "clunky". Please share your thoughts as you break them in. Also, did you talk to MT about those 2.5" bump stops? I have the 3" with my kit and both the shock and bump pad bottom out at the exact same time. I feel like the extra 0.5" up travel might harm the shock... just an observation.
John
darkhorse13 is offline
post #10 of 28 (permalink) Old 05-19-2017, 08:39 AM
Quoted: 292 Post(s)
Mine touch the tank, and I've just lived with it as there seem to be no detrimental effects (as of yet). But I am considering those offset uppers you posted. Seems like a viable option, but I need to justify the expense, not sure its an issue worth solving yet.
See here (What did you do TO your FJ Cruiser TODAY?) for the discussion we had on the coil slap.
'07 Voodoo 4x4 AT
Human Verification
