Old 09-19-2008, 12:48 PM   #1
myyellowtoy's Avatar
Member Number: 1850
Need help lowering roof rack.
ok, here it is. I have the RC 6 inch lift and 35 inch tires. Plus the factory roof rack. I'm starting a new job at a new hospital and the parking garage is only 7 ft (84inch) tall. My car is more than 84 inches. I did some measurements and if I lower my roof rack, you know remove the second level of the rack and lower the top close to the roof, the car will fit in the garage. I see that the rack is all bolts on but I might need to weld the front. What do u guys think, What is the best way to lower it? I don't want to remove it, I love the way it looks and don't want to get rid of my car. This car is mine until I die.
myyellowtoy is offline
Old 09-19-2008, 01:01 PM   #2
newfiefjtt's Avatar
Member Number: 20252
Re: Need help lowering roof rack.
check IH8MUD forums.look under "roof rack diet"
newfiefjtt is offline
Old 09-19-2008, 01:09 PM   #3
Member Number: 1850
ok i will thanks
Old 09-19-2008, 01:13 PM   #4
JoeUser's Avatar
Member Number: 15334
There are a few threads here in this forum that describe how to do it, as well.
I've done it to mine, as well. Not hard, and requires a minimum of tools and time.
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna Call Sign: KE5WTX; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTec Medium rear coils, OME N71E rear shocks); SCUBA breather mod; Steel sway bar collars; OutRider Suspension rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Metal Tech step sliders; Mini-Me OEM roof rack; ARB Bull Bar front bumper; Focuztech fog lights; Hella 500 driving lights
JoeUser is offline
Old 09-19-2008, 01:16 PM   #5
HAWKTOMAS's Avatar
Member Number: 20701
One option is to make a mini-roofrack. In this thread; Complete Roof Rack Comparison , there is a link to here; All new Roof Rack Diet... Mine was a bit too big - IH8MUD™ Forums showing how to do that. Don't know if you want to do that as an option, it would maintain the stock look at least.
"... I never drive faster than I can see, and besides that, it's all in the reflexes."
2008 SANDSTORM 6M/T
INCLUDED OPTIONS: Z2, C7, E5.
REMOVED: roof-rack, spare tire cover.
ADDED: Metal-Tech Front Bumper, Superwinch EPi9.0S, OME 3" Mediums, Trail-Gear Sliders, Baja-Rack, SCUBA-Mod, A-Trac switch, FJammer & OEM Subwoofer w/switch, OEM second horn.
ACCESSORIES: Hi-Lift Jack & Badland Bumpers tube adapter, Rigid shovel, Axe, ATV tool box
HAWKTOMAS is online now
Old 09-19-2008, 01:17 PM   #6
newfiefjtt's Avatar
thanks joeuser.i was'nt to sure where they were on here or if it was on here at all.
Old 09-19-2008, 01:25 PM   #7
Member Number: 1850
I would like to keep the stock look, want to lower it all the way from the front to the back
Old 09-19-2008, 01:27 PM   #8
JoeUser's Avatar
Using the method mentioned in the previous posts, you will lose the front part of the rack (unavoidable).
But, you would still have the lower section that uses the center and rear mounts on the roof. A good compromise, IMO.
The only other options you have are to either A) remove the rack completely, or B) buy a lower-profile rack, such as the Gobi Stealth model (or something like it).
JoeUser is offline
Old 09-20-2008, 12:58 AM   #9
VooDooSmurf's Avatar
Member Number: 20694
myyellowtoy previously said: View Post
I design parking garages for a living code is 8'-2" if Handicap parks in the garage, if the garage is an older garage it may be lower.... Most signage has a factor of error taken into account maybe acouple of inches....And the 7'-0" measuerment is probably at a drain pipe... I would take a tape measure and find out for sure you might not have to do anything or avoid a certain area of the structure.
VooDooSmurf is offline
Old 09-20-2008, 01:05 AM   #10
raYGunn's Avatar
Member Number: 21281
Try this!
raYGunns FJ "Furious Jones"
TLCA#19064
Black '08 4x4 Automatic
Demello Front Bumper
Demello Skid
Demello Hybrid Rails
Icon Suspension
Camburg UCA
Garmin Nuvi 500
Gobi Rack, Ladder and Mounts
Dirty Parts Dual Battery Setup
Warn 8000 Winch
Piaa Lights
raYGunn is offline
