>>>>>>>>>>>>>>>>>>>>>>THIS GROUP BUY IS NOW CLOSED>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>>>>>>>>>>>>>THIS GROUP BUY IS NOW CLOSED>>>>>>>>>>>>>>>>>>>>>>>>>
GB prices are: Here' is the deal. First TEN COMPLETTE Skid set will be$820+$50 S&H ====TOTAL is $870.00 SHIPPED WE NEED TO GET 10
Payments accepted are Visa, MasterCard, American Express, Discover or Cashiers Check. Shipping date WILL BE UPDATED. Might be able to go upto 15.
I will give you an order number, and you will call the contact person directly and give your method of payment, payment will be process directly through the manufacturer. Tohelp keep your personal infomation SAFE.
So far I have the following members that are Interested.
1-JOEUSER---CONFIRMED IN
2-VIKING1-NO SHOW 3-Mr R2FJ---CONFIRMED IN 4-FJTEXAS---CONFIRMED IN 5-Hondo---CONFIRMED IN 6-GTKrockeTT ---CONFIRMED IN DONE
7-Quazimoto88-NO SHOW
8-elias-NO SHOW
9-livnpaintball2-NO SHOW 10-DC Cruiser---CONFIRMED IN 11-borghete---CONFIRMED IN (Paypal is good) 12-Charlie C---CONFIRMED IN 13-GOT DIRT---CONFIRMED IN 14-Sonof40---CONFIRMED IN (Check is good)
15-Singha
(I am NOT taking anymore folks until Sat morning, waiting to see who don't confirm or cancel)
= Have been PM'd and ready to go. PM sent w/payment info.
I really like these. I'm not a hard-core rock climber, but primarily looking to protect exposed components (mainly from brush, tree limbs, and minor scrapes)...
PM sent for pricing...
Also, can you post specs (weights, link to more info, etc.)?
Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
These heavy duty FJ Cruiser skid plates are laser cut from 5052 aluminum (corrosion free) and CNC press formed. Replaces the thin factory sheet metal with heavy duty aluminum from front bumper to rear of tcase. Includes air intake for power steering cooling and oil drain holes.
Complete set for FJ
• Full coverage from the radiator to the back bumper.
• Easy installation, no drilling- fixed to the original holes in the vehicle.
• Air intake included
• No unnecessary movements and screeches
• Each skid plate is made of 5052 aluminum that is 0.23in (6mm) thick.
Total weight for complete set is 84 lbs (38 kg)
Front Bumper Skid Plate
Rasta front skid plates are the best you can find these days.
We enhanced the efficiency of the plate by adding a very important element- an Air Intake
Toyota had to add an Air Intake to cool the front differential because it is in permanent locks. When you install a front skid plate, the differential "suffers" because instead of an Air Intake, there are usually only some holes for cooling purposes.
Rasta has developed a special Air Intake specific for the FJ Cruiser front differential and it’s simulating exactly the functionality of the original one.
It’s also important to know that if you need to change the differential oil, you can do so without taking off the skid plate using the service holes we put in.
Gear Box Skid Plate
Prevent unwanted damage to your lower body with a gear box and transfer skid protection plate
Transfer Skid Plate
The “crooked” hole in this part is specially made in this shape to allow you to change your oil with no need to take off the skid plate.
Needs to be installed with the fuel tank skid plate.
Fuel Tank Skid Plate
Provides you full protection of your fuel tank from road hazards.
Needs to be installed with the transfer skid plate.
__________________ TLCA#18914 GCLC#2083 NYC
Ti 6sp. CQ GY UP C7 37 2Q. ADDED6D(x2),EL,V5,WL(x2). TRD CAI,Exhaust,Q/Shift,SE Knobs,SE Wheels,Shocks,Raditor Cap,JDM TRD gas cap cover. MODS AllPro Sliders,E-Locker skids,R-LCA,Bandi, Digger R-UCA,OME 883+TP14(w/TRDs),Hella horns,Husky mats,SGII,Osram SilverStar Bulbs,OEM Brush Guard w/Hella 500FF w/TACO switch,OEM sub, LightBar w/ 4 Hella FF50,Rasta Skid plates,TC A-Arm Skids.
Dave Crums NEW Rear Trailing Arm MOUNT.
I like the look and idea. $980 is spendy. I wouldn't get the gas tank skid so that may make it more reasonable for me. I like the rest of it quite well for my purposes.
__________________ 1 Bored Clerk
Inchworm Gear E-Locker Guard
If this was the case, wouldn't the Toyota factory front skid plate have the ducts built-in? Perhaps someone who's better versed on this topic can shed some light here...
Looks like the budbuilts weigh in at about 120lbs or so (not sure if that includes the gas tank skid). So, for 84lbs of weight savings, I'd consider doing the aluminum.
