Go Back   Toyota FJ Cruiser Forum > Buy/Sell Section > Group Buys
Group Buys This is a forum for vendors only to conduct group buys. Users are not permitted to start threads in this area.
Old 04-10-2008, 07:41 PM   #11 (permalink)
mattmainster's Avatar
Member Number: 11822
Send a message via AIM to mattmainster
Re: Light Racing Adjustable Upper control arms Group buy!
MudLovingFJ previously said: View Post
oh, i was hoping they would be similar to total chaos/camburg upper arms, not an adjustable OE style replacement...
Ditto that, I got all excited.
Snorkeled, Icons all the way around, 35" BFG A/T's...and some other stuff.
mattmainster is online now
Old 04-10-2008, 07:48 PM   #12 (permalink)
ToyTec Lifts's Avatar
Member Number: 2157
They are ofset more than the stock arms are to allow more downtravel and extra clearance between the spring and control arm at full droop.
Doug
ToyTec Lifts
http://www.toyteclifts.com
sales@toyteclifts.com
ToyTec Lifts is offline
Old 04-11-2008, 12:02 AM   #13 (permalink)
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
ToyTec Lifts previously said: View Post
But they dont look as cool...
that is still a decent price and it shouldnt be hard to get 20+ people on board
The So-Cal Safari Snorkel Install Guy 7 chicken necks installed to date
MudLovingFJ is offline
Old 04-11-2008, 08:04 AM   #14 (permalink)
Member Number: 2157
May be we could powdercoat them orange! LOL
No seriously they are about functionality. The adjustability is something all aftermarket UCAs need. I know of several FJ's that had problems with alignment after installing other brands of aftermarket non adjustable UCA's.
The ball joint is also a larger size than stock and not an exposed ball that will wear and make noise like some have.
The Icon's are great; definately the best looking, we sell those too.
Doug
ToyTec Lifts
Old 04-11-2008, 09:26 AM   #15 (permalink)
sonof40's Avatar
Member Number: 11473
Are these necessary with a standard OME medium lift?
Steve
TLCA
Sleeping/Storage build: http://tinyurl.com/367bbw
CB: Cobra 75 / Bandi http://picasaweb.google.com/steven4m/CBInstall
Back Door Inside Latch: http://tinyurl.com/2jxwkk
sonof40 is offline
Old 04-11-2008, 09:42 AM   #16 (permalink)
Member Number: 2157
sonof40 previously said: View Post
That question could stir up a major debate
Honestly I dont think so; neiter does ARB/OME but I have seen where the caster does get all the way on the lower end or out of spec when you are pushing 3" lift or more in the front. These control arms will compesate for that and add some adjustability which will give better control.
We have 3 1/2" lift on the front of Don's FJ and the same on the front of our 2007 4Runner with stock upper control arms. The alignment on both was adjustable to within spec except the caster was on the low side. They both drive great although there is a more stable feeling driving a lifted FJ with aftermarket UCA'a
Doug
ToyTec Lifts
Old 04-11-2008, 02:38 PM   #17 (permalink)
Member Number: 2239
Do they offer anymore tire clearance? If you could run a 285/70/17 on a tacoma with these with stock wheels you would probably sell a ton of them as they would serve two purposes then, fix alignment and allow bigger tires on OEM wheels.
I ran TC UCA's on my 05 tacoma and HATED them, they constantly squeaked from the time they were knew until I sold the truck, I could get them to stop squeaking for a few days by loading them up with teflon lube but then it would come right back....the sealed ball joint on these are really appealing to me.
justinh is offline
Old 04-11-2008, 07:05 PM   #18 (permalink)
Member Number: 2157
justinh previously said: View Post
As far as the clearance; good question! We are looking into that now, I will have an answer Monday.
We have aftermarket UCA's on our Tacoma too and have noise problems everytime we go off road; it comes back squeeking like crazy! We also have too much caster after all was said and done; it affected the camber setting and we could not get it low enough to avoid tire wear.
We never try and bash any other companies products but I think the light Racing UCA's have some definate advantages over other's on the market, at the same time if you are running the baja something else may be the ticket!
Doug
ToyTec Lifts
Old 04-15-2008, 01:28 PM   #19 (permalink)
Member Number: 2157
Update:
The Upper control arms definitely do have additional clearance in both the area between the tire/control arm and the area next to the spring on the inside of the arms.
I am trying to get a set of the stock arms so I can post pictures of the additional clearance.
Doug
ToyTec Lifts
Old 04-18-2008, 11:27 AM   #20 (permalink)
Decidion's Avatar
Member Number: 13809
After getting my Sway-A-Way suspension installed, the alignement center could not get my alignment completely within spec at the full end of the adjustment range. Close....very close....but not completely. I am sure these (or any of the other aftermarket UCAs) would do the trick. Just.....need.....more....mod....money!!
Maybe I can win a set at the Summit Raffle
Decidion (Jeff)
'08 Brick Red
CF-CQ-UR-3T-C7-2Q | OEM Brush Guard || OEM Rock Rails | Tail light Guards | Magnaflow 11226 | AFE CAI | Bud Built Skids | Custom Console | VentShades | SCUBA Driver Mod | Blacked-out Bumpers | Rear Storage Shelf | IPF 968s w/Clear Covers | BFG 285/70R17 A/T KOs | SAW RaceRunners | Hi-Lift Extreme | Staun Deflators | Midland 75-822 w/Bandi Mount | OXT Shock Guards | Tantrum Rock Lights | Kelty CarTarp
Decidion is offline
