Go Back   Toyota FJ Cruiser Forum > Buy/Sell Section > Group Buys
Group Buys This is a forum for vendors only to conduct group buys. Users are not permitted to start threads in this area.
Old 10-23-2009, 08:43 PM   #351
Member Number: 20029
Send a message via AIM to jszostek
Re: Lucrum Swing Out - LAST CHANCE!!! This is it.
chris, how does the secondary bracket mount?? the instructions do not specify
jszostek is offline
Old 10-24-2009, 10:11 PM   #352
Lucrum's Avatar
Member Number: 3193
jszostek previously said: View Post
On the second page of the instructions there is a diagram with the parts labeled for you. The secondary brackets are pictured just below the primary brackets shown installed. here is a link to the instructions. Lucrum ind. Also step 7 goes over the install of these as it depends on what bumper you have. If you have the all-pro, you do not use them. But hang onto them because if you ever change your bumper or something you might need them later.
This might help as well;
The secondary bracket mounts in between the primary bracket and the frame. If you look at the instructions they describe how to mount it, but to maybe make it more clear, the top of the secondary bracket has two slotted holes, these holes are to be lined up with the two holes in the primay mounting brackets that match up as shown in the picture. Once you line these two holes up and mock up the bracket in place, then look to the other end of the secondary bracket. On the opposite end you have another slotted hole, mark where this lies on the frame and drill and tap your 3/8" hole for the bolt that comes with the kit.
To sum it up, you are using the secondary bracket to tie the primary bracket into the frame.
Lucrum is online now
Old 10-24-2009, 10:30 PM   #353
also in the picture at the beginning of this thread shows a bar that that goes up on the tire side of the swing out for the shovel and axe.. however mine does not have that bar and i cant seem to make space for the shovel and axe...
jszostek is offline
Old 10-25-2009, 01:38 AM   #354
Lucrum's Avatar
Member Number: 3193
The bar that goes up the tire side in the picture was a early version of the antenna mount while it was going to be a accessory. We made it standard and incorporated it into the design to add more utility to the unit. The design did not change to the axe or shovel area and is still the same as pictured. To store the axe and shovel you can mount them as pictured in the instructions.
Did you receive the instructions? If not you can download them on our website in the link I put in the last post, but am always happy to answer any questions.
Old 10-31-2009, 02:41 PM   #355
Brock's Avatar
Member Number: 18654
Send a message via MSN to Brock Send a message via Yahoo to Brock
Tried to install today...got Warn off...got bearings greased and fitted into races and swing arms. Started drilling holes but need better bits and longer ones that will reach all the way to top.
So stopped and will try and finish tomorrow.
USAF (Retired)
NRA Life Member
Lowcountry Land Cruisers
she's a Brick.......House
08 FJC, Brick, Auto, Nitto Terra Grapplers (295), ATrac, Locker, Budbuilt skids and sliders, ToyTec 3" OME lift, Warn rear bumper with Lucrum Swingout Tire kit, Demello custom 3hoop front bumper with Titan12,000 winch,
84 FJ-60, blue, BDS 2.5" lift, BFG KM2 33x10.5x15, CCOT console, no rust
Mystique's build thread (FJ60)
The BRICK-HOUSE build thread
The Lowcountry Land Cruisers
Lowcountry Reflections
Lowcountry AMSOIL Products
Discount Tire Direct
Brock is offline
Old 11-01-2009, 08:23 PM   #356
Brock's Avatar
Okay almost done.... here are some truths to believe...and take serious.
1- When Chris says mount the main mounts as close to body towards front as humanly possible....do it.
2- When you drill your holes...it is better to put it up on a rack to drill or get an attachment to hold the drill bit square to the frame rail.
3- If you have an aftermarket bumper already might not need to remove the plastic corners like you would with stock bumper...as they are already cut...but may need to cut more. I did.
Mine is 90% mounted....some mistakes I made but think it will work out. I drilled a hole off line so one of my mounts sticks out further than I intended...which seemed fine except now I cant get one of my bumper bolts back in due to alignment. Drilling another hole wont work...so may be tac welding a spot to make sure it stays put.
When it is all done will take some pics and post... Thanks Chris for the hard work..it is very solid. I am not much of fabricator so things that might be easy for most of you guys is a struggle for me.
USAF (Retired)
NRA Life Member
Brock is offline
Old 11-01-2009, 09:04 PM   #357
spincycle's Avatar
Member Number: 9041
I may be doing this install (on a warn rear) sometime in the next week in the Boulder, CO area. Anyone around who's willing to lift steel, laugh at me and ultimately be able to claim wrench-time on the uber-SUZ, lemme know.
Suzie ('SUZ') the '07-6MT-FJC
TLCA#17822 / FCC:KD0ECN / Blue Ribbon Coalition / Navy League#101495511
Thanks To: BajaRack, BF Goodrich, Budbuilt, Camping Labs, Engel, KC Lighting, Lucrum Industries, Powertank, ProComp Wheels, Springtail Solutions, Tuffy Storage, Underdog Racing Development, Valentine One, Yaesu Radios, Outrider Suspension Armor and TOYOTA
Net Home || Flickr/Pics || Twitter || Old Blog & Experimental Domain
spincycle is offline
Old 11-02-2009, 06:43 AM   #358
Brock's Avatar
I will try to get you some nots on installation and lessons learned before then since I have a Warn too. Hopefully I can keep you from needing to get out the cutting wheel and notch your bumper to fit like I did. LOL
USAF (Retired)
NRA Life Member
Brock is offline
Old 11-03-2009, 08:20 PM   #359
spincycle's Avatar
Member Number: 9041
Brock previously said: View Post
Would be very appreciated! Should be starting late this week!
Old 11-03-2009, 08:56 PM   #360
Brock's Avatar
Mine is installed....have to add axe/shovel mounts and hi-lift mount and I have it all done finally. think i am going to get the upper rack or the can locks..not decided yet.
i head out on Friday for weekend of camping in mountains...so if you want we can talk on Thursday if you got time during day. PM me a time and number to talk. Good luck.
Will get out some pics tomorrow for everyone to see
USAF (Retired)
NRA Life Member
Brock is offline
