Go Back   Toyota FJ Cruiser Forum > Buy/Sell Section > Group Buys
Group Buys This is a forum for vendors only to conduct group buys. Users are not permitted to start threads in this area.
Old 06-20-2009, 02:45 PM   #21
Member Number: 25644
Send a message via Skype™ to 2WhiteHummers
Re: Staun Tire Deflator Group Buy
HOW TO DEFLATE YOUR STAUN TIRE
DEFLATORS
STAUN TIRE DEFLATORS ARE BY FAR THE QUICKEST AND EASIEST
WAY TO REDUCE TIRE PRESSURE - SAY GOODBYE TO THE HASSLE OF
FIDDLING AROUND WITH KEYS, MATCHSTICKS OR POOR QUALITY
DEVICES
Basically all you have to do is screw a deflator onto your tire valve stem
and then leave them to do all of the work - YOU DON'T EVEN NEED ANY
TOOLS TO USE THEM!
The deflators are supplied at a preset you can adjust this pressure to your desired level. It is not necessary to reset them again
unless you wish to change the psi that you
Exactly how much you reduce your tire pressure depends on a variety of
factors, such as how much weight your tires are supporting. Additionally
the softness of the surface that you are travelling through will also affect
how much you need to let your tires down. Through trial and error you can
find your personal preference and determine what tire pressure suits you.
Staun Tire Deflators do not have a minimum start off pressure so you do
not need to bring your tire pressure back up in order to reduce it further.
Simply turn the adjusting cap anti-clockwise to further reduce your tire
pressure. If they do not start automatically you can manually start them by
lifting the pin. Please check your product header card for individual
pressure settings.
The Staun Tire Deflators need to be screwed on from the finger grip located
at the base of the valve. Do not use the adjusting cap or lock ring to fix the
deflator to the valve stem. For a comprehensive demonstration on how to
install the deflators onto your tires please view the video above.
Disclaimer - Subject to any applicable statutory rights, the manufacturer
(including any authorized agent selling the product) expressly limits any
liability with respect to the product to the person who purchased the
product from the manufacturer or authorized agent and such liability is
expressly limited to the cost of replacing the product.
This product is designed to be used to deflate tires through quick release
of gas pressure and no eyes, ears or other body parts should be placed
near these escaping gases. Further, the product should only be used in
close proximity to a device that will inflate tires to manufacturer's
specifications. The manufacturer and its agents shall not be liable or
responsible in any event for the device completely deflating any tire below
the tire manufacturer's specifications.
Home page a subsidiary of HummerGearSales.com, Hummer Tire Cover, Hummer Accessories
2WhiteHummers is offline
Old 06-20-2009, 06:12 PM   #22
FJeddah's Avatar
Member Number: 19121
They come adjusted to what PSI?
...Save Gaza...
'08 Black Diamond (5AT) 4X4
Birthday: April 19, 2008
Desert Knight - My Build-up
FJeddah is offline
Old 06-20-2009, 09:43 PM   #23
The SCV5 (this is the one we have the group buy listed for) come pre-adjusted to 18 psi and you can adjust them from 6 psi up to 30 psi.
FJeddah previously said: View Post
Old 06-20-2009, 09:49 PM   #24
By the way, we do have the Staun SCVHD Deflator (pressure range is 15 to 55 psi) in stock if anyone is interested.
Old 06-21-2009, 05:03 AM   #25
FJeddah's Avatar
2WhiteHummers previously said: View Post
This is good, I would need to deflate my tires to 11 PSI.
Are we close to $55.95?
Thanks
...Save Gaza...
FJeddah is offline
Old 06-23-2009, 07:04 PM   #26
Kosmo's Avatar
Member Number: 18953
...I'm in but I just got a headache reading that 4 times to be sure I read it correctly...
http://www.fairtax.org
"I like stuff...stuff is cool"
Kosmo is offline
Old 06-24-2009, 05:07 AM   #27
C5Drvr's Avatar
Member Number: 4728
Arrggghhh.... I want these before the FJ Summit. I leave on the 11th and this doesn't close until the 17th.
'07 TRD SE "The Black Hole"
6MT, Loaded, aFe CAI.
ARB Touring Rack with Simpson II RTT
OME Med, Safari Snorkel
Steelies w/ 34x10.5R17 Super Swampers
Stock BFG AT/KOs for Daily Driving
MetalTech Front w/ new 5250 Alum Bash Plate
PIAA 520 Crystal Ion Fog/Driving
Ricochet Skids (in the mail)
TLCA 19588
GCLC 2130
FJNorthEasters.org
C5Drvr is offline
Old 06-24-2009, 01:57 PM   #28
C5Drvr's Avatar
Member Number: 4728
Allright, I'M IN!!!
TLCA 19588
GCLC 2130
FJNorthEasters.org
C5Drvr is offline
Old 06-24-2009, 02:33 PM   #29
ANGRY BARBER's Avatar
Member Number: 18635
Paid
-BRUTUS-
MODS: SURFER FOOT GAS PEDAL
"Don't you sabotage me Miles, don't you do it...and if they want to drink Merlot, we're drinking Merlot"
"No, if anyone orders Merlot, I'm leaving. I am NOT drinking any fܢk!ng Merlot!
TLCA# 18845
ANGRY BARBER is offline
Old 06-25-2009, 01:01 AM   #30
the paragon's Avatar
Member Number: 16806
Send a message via Skype™ to the paragon
how come I don't see my name on the committed buyer list?
the paragon is offline
