Re: Shovel & axe mounts on the cheap for the stock rack
The Hi-Lift ideally should have bigger diameter bolts like on my Slee mounts.
Used with Yakima 10V Vertical Mighty Mounts.
I have pics on my website in the 4Runner mods section using the Slee mounts with the Hi-Lift.
However I will not be mounting it up there, to hard for me to lift it up.
I have been in contact with Man-A-Fre who sells the Kaymar Hi-Lift brackets to see if they will make one for the FJ.
Using the Slee mounts on the 4Runner was easy, the roof was lower than the FJ.
__________________ 2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, to much to list, see my website & buildup thread
I also put an email into Yakima yesternight to see if they have any Snap Arounds like that go on their crossbars that are bigger diameter sized at 1.75" like the sides of our racks.
If so...you could mount the Hi-Lift to the sides like the Demello mounts for cheap.
Even I can lift the Hi-Lift to the side of the rack, but on top it is just to hard, even on my 4' ladder I use to wash the rig with.
I am not giving up on Kaymar either to make one for the spare tire.
This is a lil off topic but I wonder if it's a good idea to have holes in the handle of the axe especially near the neck. Seems like it would compromise the structural integrity.
Not one bit.
It is a solid fiberglass, I know many who have ran the same setup for years with no problems.
I got a reply from Yakima, and as before when I asked about the 23H mounts several weeks back, they are clueless there, and do not know to much about their own stuff.
I had asked if they had some bigger 1.75" diameter mounts that might work.
Unfortunately, we do not. Our Snaparounds are only made to fit our round bar or Thule's square bar and the Mighty Mounts are specifically made for each factory rack. I do not have a reverse way of fitting Mighty Mounts. I apologize for any inconveniences.
So it looks like I will have to pony up the $90 for Demello's mounts, or wait and see if one of Kaymars spare tire mounts will work from Man-A-Fre.
