First and foremost I'd like to thank FJ Dragon for his intitial write up on "
homemade Foglight Brackets" Primarily beacause I started with his bracket setup and modified it a bit for my purposes. So hats off Dragon, thanks a ton. I'd also like to thank "Mo" for his write up on installing his Hella's and switch!
Here is the grill removed and my brackets mounted. I used the same riser measurements as Dragon, but added a inch in height. Next came a cross bar to give me a little more width and then I continued with Dragons Measurments again and just bolted them further out to support larger offroad driving lights. I went with 6" Hella Black Magic's and I've got to say they are awesome.
Here they are installed.
A side view.
Front angle.
Relay mounted.
Inline Fuse
Firewall port.
Swith.
Now on.
Little darker out.
Night.
Here is the Diagram the best I could Corel Paint.
And I'll try to get a few when it gets darker if anyone wishes.
Oh and here's my mountain getaway ... 7 miles from MT. Mitchell and the reason for the lights.
Thanks again Dragon!!
........Dan
