Old 10-20-2006, 06:19 PM   #1 (permalink)
Banned
Tony5150RN's Avatar
Member Number: 2259
Angry Rear door cargo net issue.
Anyone else having issues with one, or both, of their rear cargo nets? I've had a 100 feet of light robe stored in my top net for about a month. The rope isn't very heavy but is bulky, size wise, and sticks out. Today I noticed a silver, coat hangar looking, wire coming out of the bottom of the top net. Apparently, it holds the bottom of the net in place under the plastic edge. I tried pushing it back down only to have it pop back up after a short trip. What a cheap piece of garbage, what good are they if they can't hold a low weight item?
Anyone know of a fix for this??
Tony5150RN is offline
Old 10-20-2006, 06:23 PM   #2 (permalink)
Member Number: 2287
Re: Rear door cargo net issue.
hmm, when installed mine, I figured something like that could happen. I don't think there's a real solution because weighted objects over time will pull on the net. Then that bows the bottom wire frame, as you're seeing now. I only leave the first aid kit and rags/shirts in there.
Even if you pop it back in, the plastic rivets don't have enough force to hold that lower rail tight.
Sun Fusion Auto 4WD - FE, CQ, UR, Z1
Mods: BFG 285 70/17's on stock alloys, Aeroflow headlight covers, FJ3-FRCC Toytec Lift Kit with OME-N71, Demello sliders, dual rear cargo nets, stock tow hitch, DICE iPod kit, Yakima rack with StornCo adapters, SwissArmySUV Overhead map light, 2008 Side Visors
oldskoolboarder is offline
Old 10-20-2006, 06:24 PM   #3 (permalink)
Hwtrader's Avatar
Member Number: 3787
I have the fix for you.
Remove the clips holding the bottom rail onto the door panel. Move the wire below the clips and reinstall.
Hwtrader is offline
Old 10-20-2006, 06:33 PM   #4 (permalink)
Banned
Tony5150RN's Avatar
Member Number: 2259
Question Re: Rear door cargo net issue.
Hwtrader previously said: View Post
They should have noted that in the installation instructions, but most of these have the same problem (improperly installed).
HW, sounds like you're on the right track. How do I remove those clips?? If I do are they reuseable??
BTW, thanks for the fast replies. You guys rule!!
Old 10-20-2006, 06:36 PM   #5 (permalink)
Hwtrader's Avatar
Member Number: 3787
They are push in retainers in the center. you can get behind them with a screwdriver and pry out the center parts. Once the centers are out the clips can be pulled out with the rail. Push the centers in to refasten it to the door.
Upon closer inspection I think this is a Kludge rather than the way it was designed, but so far mine works great and has given me no problems.
I my second one just now and looked closer at it. The wire was supposed to be above the clips, but works fine below it.
Hwtrader is offline
Old 10-20-2006, 06:39 PM   #6 (permalink)
Member Number: 2287
I stand corrected, yes, that should work...
Old 10-20-2006, 06:41 PM   #7 (permalink)
Member Number: 4546
If you have gaping in the center, you can weave a thin black bungee cord just underneath the top collar, and anchor through holes in the rear panel (I just tied a knot on both sides. Works really well. True, kind of a pain the arse to take the door panel off, but I was already in there scouting and prepping it for a rear door sub mount.
socalboo is offline
Old 10-20-2006, 06:55 PM   #8 (permalink)
SoonerFJ's Avatar
Member Number: 2501
I use a "Transit Rack Strap" that is woven through the cargo nets to give it more support and carry extra weight without deforming the mesh of the net. They cost about 3 bucks a piece and work great....just like the one below, but in black. Bought them from my local bicycle shop. Similar to a bungee cord, but flat.
eBay: 2-Pack Bungee Cord Rack Strap 24" Red New (item 160042694617 end time Oct-24-06 18:16:08 PDT)
SoonerFJ is offline
Old 10-20-2006, 07:04 PM   #9 (permalink)
stnmikita's Avatar
Member Number: 4279
I have to say, some of the rear compartment crapcessories leave a little to be desired in the quality and design department.
My wonderful dealer forced me into several unwanted "upgrades" in order to get my black beauty. The most egregious of the bunch by far was the cargo cover which was not only flimsy and cheap in quality, but an absolutely horrible design both to install and use.
I'm sure the powers that be will iron out all of these issues for the '08 model year.
In Toyota We Trust,
Stnmikita
stnmikita is offline
Old 10-20-2006, 07:13 PM   #10 (permalink)
Banned
Tony5150RN's Avatar
Member Number: 2259
SoonerFJ previously said: View Post
Any pics of how you did it??
