Old 10-21-2006, 08:48 PM   #1
On Pilgimage
Member Number: 2479
Dakar Bar Stock Headlight Obstruction Fix
Well, I couldn't notice any difference in the lighting, but there was a nag in the back of my mind that my lights may be partially obstructed by the fog lights mounted on my Dakar Bar in the default holes.
So, since I had to spend part of the day at work today, I ran out in the shop for a while.
I cut a 31" x 1-1/2" bar of 1/4" thick material. I drilled holes in the same locations as the Dakar bar so that I could mount the bar onto the Dakar tabs.
I then drilled two holes for the fog lights in the new bar, just inside the tabs. The center driving lights I kept in the same location. Here is the result.
No more obstruction.
Dragon is offline
Old 10-21-2006, 08:51 PM   #2
On Pilgimage
Member Number: 2479
Re: Dakar Bar Stock Headlight Obstruction Fix
Oh yeah, and my headlights are now PIAA H4 replacement bulbs.
Dragon is offline
Old 10-21-2006, 08:53 PM   #3
Banned
Member Number: 3655
Nice fix. Looks much better. Did you switch out the bulbs in the headlights too? Looks like they have a blue tint to them now.
edit: you posted at the same time as me, you did switch them.
Sun Fusion Cruiser is offline
Old 10-21-2006, 08:55 PM   #4
Bang Bang's Avatar
Member Number: 3795
Nice mod to your mod for your original mod!!
Mike
Where do you park your ride? Check this out...GarageFreaks.com
2007 2WD SUN FUSION FJ Cruiser - Acquired 07/03/06
1977 FJ40 LandCruiser - Acquired 05/30/09
Bang Bang is offline
Old 10-21-2006, 08:57 PM   #5
On Pilgimage
Member Number: 2479
Bang Bang previously said: View Post
Yeah, I'm done with lights for a while. Just a bit more $ and I'll be moving on to bigger things.
Dragon is offline
Old 10-21-2006, 09:03 PM   #6
1983FJ60's Avatar
Member Number: 2652
Do a lot of nighttime rally racing?
roll tide
1983FJ60 is offline
Old 10-21-2006, 09:08 PM   #7
On Pilgimage
Member Number: 2479
1983FJ60 previously said: View Post
No. No I don't. I like lights up higher than any water I might go through. I had a Suzuki and a Tacoma with the same set up (minus the Dakar Bar).
Dragon is offline
Old 10-21-2006, 09:11 PM   #8
1983FJ60's Avatar
Member Number: 2652
FJ Dragon previously said: View Post
It was a joke, but the setup screams a desert racing truck.
The Dakar bar is the most ideal setup for lights--since at the front of the vehicle is where you get the best illumination of the road ahead.
On the roof you're just blasting your hood and the sky, and either pretty damn stupid.
I'm mounting a set of IPF Supper Rallys on the ARB bumper of my 40.
roll tide
1983FJ60 is offline
Old 10-21-2006, 09:13 PM   #9
On Pilgimage
Member Number: 2479
I looked at the IPF's, but with no report (good or bad) on their performance, I stuck with what I knew. Can't wait to see the pics of your set up, if you post them somewhere.
Dragon is offline
Old 10-21-2006, 09:14 PM   #10
1983FJ60's Avatar
Member Number: 2652
I looked at the IPF's, but with no report (good or bad) on their performance, I stuck with what I knew. Can't wait to see the pics of your set up.
I got sidetracked with bleeding the brakes on my mountain bike and barfed DOT 3 brake fluid all over the garage floor.
roll tide
1983FJ60 is offline
