Re: How to disable drl's?
ok, mine is a 2007 with hid kit, i unplugged the connector bhind the headlight and nothing, i cut and switched the small blue wire on the drl's relay bos and nothing. i do turn them off when turning off applying brake and turning on, but as sson as i release brake they turn back on. HELP,, dont wanna have to be replacing ballast or hid bulbs more than normal. by the way, these hid kits that i bought are BRIGHT! i have to turn on the hi beams because they are actually dimmer than the hid's. im wondering if thats the problem>>>
