Heated Mirror - Full Install - Page 6 - Toyota FJ Cruiser Forum
 1Likes
post #51 of 107 (permalink) Old 04-09-2008, 01:10 PM
SwiCago's Avatar
Quoted: 191 Post(s)
Re: Heated Mirror - Full Install
Thanks for posting an online vendor...
they have the bigger ones too .. 3804
SwiCago is offline
post #52 of 107 (permalink) Old 04-09-2008, 03:47 PM
Quoted: 4 Post(s)
SwiCago previously said: View Post
Yes they do...just changed my order
They can also order the replacement glass, Burco part #4131(driver $18) & #5226(pass $24).
Mwhy is offline
post #53 of 107 (permalink) Old 05-09-2008, 07:55 AM
pippenger's Avatar
Quoted: 0 Post(s)
Burco | Home
Has anybody used the 4131 & 5226 Convex part number(s) in your mods? Looks like they make the mirrors for it. Wonder if this wiring harness hooks to them? I want to start this mod, but thought the whole mirror may be a little cleaner. Anybody out there tried this method?
pippenger is offline
post #54 of 107 (permalink) Old 05-10-2008, 07:41 AM
Steve_53's Avatar
Quoted: 3 Post(s)
The Burco parts (4131 & 5226 ) are simply replacement glass (should something "bad" happen when you remove the stock glass from the mirror carrier). Using the Burco glass still requires the add-on heating elements and "do-it-yourself" wiring.
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N air filter, Trail Gear sliders, In-Channel Vent Visors, Parrot CK-3100 bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
post #55 of 107 (permalink) Old 05-28-2008, 10:34 AM
Quoted: 4 Post(s)
****WARNING****
Burco redi heat 3804's CANNOT be cut, even though the paperwork you get from Burco says they can be trimmed horizontally with the heating element lines. I learned the hard way Burco is looking for a better replacement then the 3801 and 3804 part numbers for me. I'll let you know what the part numbers are when I get them.
"Silence is golden, but duct tape is silver"
Mwhy is offline
post #56 of 107 (permalink) Old 05-31-2008, 12:00 PM
SwiCago's Avatar
Quoted: 191 Post(s)
Mwhy previously said: View Post
Bummer, so they don't fit 100% .. Wonder why SwissArmySuv told me that you can use the 3804's .. I once sent him a PM asking where to buy the 3801's online and part of his PM reply was
SwissArmySuv previously said:
if I were to do it over, I would use pad # 3804 .. this pad is a little larger and a number of the guys have used it instead of the 3801.
So from that PM, I assumed the 3804's worked...maybe he or some of the folks using the 3804's can chime in and let us know how they got them to work ???
SwiCago is offline
post #57 of 107 (permalink) Old 06-01-2008, 07:45 AM
Steve_53's Avatar
Quoted: 3 Post(s)
It was my experience (when I did this almost a year ago) that Burco was putting all sorts of different shaped pads into boxes labeled 3804.. I ended up using 3801's because I couldn't find a pair of 3804's that even matched each other - never mind the pictures on Burco's website.
Steve
Steve_53 is offline
post #58 of 107 (permalink) Old 06-01-2008, 08:57 PM Thread Starter
SwissArmySuv's Avatar
Quoted: 2 Post(s)
others have used the 3804's. here they are layed out on an actual mirror cut-out.
The tab on the lower left on the second picture can be removed.
SwissArmySuv is offline
post #59 of 107 (permalink) Old 06-03-2008, 05:25 PM
Quoted: 4 Post(s)
SwissArmySuv previously said: View Post
Interesting Swiss. The 3804's I received are MUCH larger then those, but shaped the same. I cut them according to the directions, and no heat I called Burco, and they sent me some replacements free of charge, since their paperwork says you can cut them horizontally. The tech I spoke with said the newer versions CANNOT be cut
I think the replacements Burco sent me are a little smaller then the 3801's...
Mwhy is offline
post #60 of 107 (permalink) Old 06-05-2008, 08:52 PM Thread Starter
Quoted: 2 Post(s)
shucks, I wonder if they made some changes?
Human Verification
