I used these nicely shot photos from another member's thread; m3pedro, I hope you don't mind. They gave me an idea, and I wanted feedback from others.
For me, the problem with relocating the washer fluid reservoir is that I have a 2013 FJ. The Expedition One reservoir would not work for me, because the newer FJs have emissions stuff located there. It has been suggested to move that (emissions items) to near the passenger side firewall first, but I intend on placing a 2nd battery there.
Has anyone considered enclosing the front side of the fluid reservoir with sheet metal armor fabricated to fit in front of the reservoir instead of relocating it?
Those three visible studs the bumper mounts to could be used as one of the attachment points.
There are many options for this. Relocating the washer fluid container is pretty simple as any container, with or without pump can work, Several have found good candidates at the junk yard, removing them from different vehicles.
I'd pick the spot and start looking for a different tank.
it has proven to be a vulnerable spot if you wheel...
even if you don`t, a cover might suit you if it is made well and sturdy, otherwise IMHO it would be bulky and just as fugly...
just try not to do it to cheap to the point that it is a flimsy POS, this is something you rely on and use often...
I've probably read all of them. Imagine my second battery by the passenger firewall. Imagine a 2013 FJ with emissions crap where the Expedition One alternative would go. Imagine custom fabricated steel armor protecting the oem location. Catch my drift?
I know what others have done. Thinking outside the box, pun intended.
I think the best solution is simply to have a single higher capacity battery instead of using two, them just doing as others have with the relocation.
When I mounted my new bumper, I simply folded forward the wheel-well liner that I would have otherwise trimmed off and added a piece of wheel-well liner from the other side to add a protective wrap. It sticks out far less than the picture suggests and has held up fine.
Yep, thanks. Read that one too. I even spoke with Jason Demello a few days ago, but as of yet, no easy solution. I believe Toyota's reservoir location choice was as a counter-balance to the battery, and also to keep the C.O.G. low. I like the idea of customizing armor to at least protect against flying debris. I haven't seen anyone actually relocate that emissions stuff yet, but this all should be quite interesting.
G'day,
I've been pondering relocation of the water bottle for other reasons, but eventually decided not to pursue it. After buying various bottles, including an exp 1 bottle ...
As I do not really use the water bottle, never wash my screen with it.... Replacing it with a much smaller bottle was my best solution.
But in the end changed direction..
Cheers Baz
G'day Doc,
Some more brain fodder..
The best place I came up with to relocate is in the bumper...
There is plenty of room inside the stock bumper, for a exp 1 bottle...
Or if you are running an after market bumper... Then a much smaller bottle should be able to fit..
Cheers
Baz
But if you want to skid it, Shrockworks has a skid for the Tacoma that I believe they said could be or they could design to fit the FJ, since they are the only ones I've heard of to even make a skid for this you might want to contact them about the option
It may not be pretty, but I created my own today on my 2010. $11.00 universal 2.5 qt. reservoir from O'reilly auto parts and a 1 1/4" hole saw. I just filled the top and bottom nipples with silicone.May have to refill it more often, but so far I'm pretty satisfied.
I was speaking with the guys ARB USA a few months back - talked about this specific issue. They do make a metal shield for the washer reservoir. It's an optional add on for their bumper. Sorry can't recall specific part number
EDIT: found the info on the ARB Part in my email
"yes there is an auxiliary kit for the washer bottle protection(part# 3520020) that was designed to take care of the lower bottle. You will see it in the instructions as well."
Doc, have you followed Lzalusky's build? It is exactly what you need to solve your issues under the hood. He has a 2013 just like your FJ and mine. I've purchased the system and it is awesome. Check out his build! If nothing else you will get some great ideas.
Sorry Doc,
I was posting the above with only one eye open last night. I think if you take a look at Lzalusky's dual battery and washer bottle relocate projects you will find an elegant solution. It would relocate the washer bottle and provide space for a dual battery set up. You don't have to use the dual battery set up if you don't need that, or you can add it later.
This is a much better solution than a mini bash plate for your OEM washer bottle. I've watched your build and noticed you mod your vehicle in a careful, well thought manner. The products Lzalusky designed are right on par with your build style. Take a look at his build. :smile
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.6K members
Since 2005
