I purchased the sport pedals for the AT transmission, I've spent the last hour trying to get the accelerator pedal on, with no luck(And I haven't even messed with the brake pedal yet!) I'm following the instructions, using soapy water for lubrication etc. Any tips on getting this sucker on?
"Everyone plays the hand they're dealt, and learns to walk through life themselves. Not everything in life is handed on a plate, when people think your words are true, it doesn't matter what you do. I sold my soul to get here, & how about you?" - Aaron Lewis
which pedals are they? how do they mount? do they just slip over the metal footpad?
I bought the same ones. The Toyota dealer told me they were very hard to get on. One trick was to heat up the rubber with a heat gun or hair dryer. I have not installed mine yet.
TLCA#16292 Toytec custom coil lift,SS brake lines. PM me for Discountshttp://www.toyteclifts.com/fjcruiser...ruiserliftkits All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts. Spidertrax spacers. All-Pro HD LCA's,Bandi mount. FabFours front bumper w/PIAA lights
Stock Toyota steel wheels with 35" MTZ's.Gas/water cans mounted to stock rack. Midland hand-held CB. Thule fairing. OEM rock rails. A-Trac/Locker hack.
Made by Autobahn Kraftworks, Indeed they slip over the current footpedals using rubber-lips that you must fit around each side of the pedal.
Note: On the brake pedal, you take the factory installed rubber cover off, the accelerator's however is glued to the pedal. Any information/tips are much appreciated!
after you suds it try using a shoehorn or maybe one of those tool you put heelies on your girls shoes> Try starting from the top down with it... Good Luck
You know, I tried ***** footing around with a prying screwdriver and such ... then ... I went and drank a forty!! Upon my return .. I learned if I got one edge on, then pulled very hard the opposite way, the opposing side would fill into place - I was clawing in there with my fingers too. You just have to get rowdy with those things and forget being polite!!
I know right now I could put on a set in less than three minutes.
- Ignorance and Apathy. Note: My sig links are often offensive, raunchy or outside the bubble; clicking means leaving the forum; don't likey?, don't whiney. Only you control your browser. 'Pause' at the beginning of a video allows the buffer to fill and means a more pleasurable viewing experience.
Will play with it tomorrow morning once the sun shows its face!
I installed the exact same pedals on mine. The brake cover comes right off,then the new pedal goes in its place. easy install. The gas pedal is more difficult. Use lots of soapy water on inside of the new cover. leave the old
cover on because the new one goes over it. Start at the top and work down the sides,then the bottom. It is a real pain but with the help of a stubby flat head screwdriver it will eventually slide on. Took about 20 min just on the gas pedal. Good luck.
Does anyone have a pic of these? I'm kinda curious.
2007 Ti FJ Cruiser - 6MT "C Package" Current Mods
- OME 886/895
- AllPro skids
- JBA exhaust, TRD Intake & AFE Throttle Body Spacer
- Expedition One front bumper and sliders, AllPro air dam, Gobi ladder & 20% Tint
- KB Voodoo's console cover and bike rack, Ellis Precision "ohsh*t" handles, Scangauge II & TomTom One I can has off road?
