I'm looking to buy a Manik light bar that will attach to the roof. I plan on using four PIAA 520 driving lights. Has anyone used a similar setup? If so, could you please give me some tips on the install. I also will use a Genuine Toyota Fog Light Switch Kit and was wondering if I should use one or two switches?
PM CruiserLarry from Dirty Parts. He sells this equipment and is a wizard at installs.
TLCA#16768
33' BFG MUD's, Icon Front Coil Overs, OME Rear Shocks and Coils. ARB Bumper, Warn 9500XD winch, MAF Sliders & Skid Plates, Gobi Ranger Rack w/ PIAA Lights ft, rr, sd, w/Gobi Hi Lift, axe and shovel Mounts, dust lights. Dirty Parts Dual Battery System, Cobra 75 WX ST CB, Extreme Hi Lift Jack, Power Tank 10 lbs. CO2 System, All Pro HD LCA's, Custom Rear Drawers. Custom electrical.
Re: Manik-Rack Mounted Light Bar
Just got my manik roof rack bar today. took about 15 min to install. super easy and looks nice too. i just temporarily stuck 2 cheapo autozone lights on there to hold me over until i get the piaas or ipfs. i say get it and if you are in socal i can help you install if you need...
__________________ 2007 Sun Fusion Cruiser 5AT 4X4
The So-Cal Safari Snorkel Install Guy7chicken necks installed to date
i actually got it from a local manik distributor here in california. they are located in irvine. their number is (949) 955-1501 (california auto trends) they gave me a good deal. or go to Manik® Original Off-Road Equipment :: Manik Homepage ; store locator. if you wanna buy from the distributor in irvine tell them arien with the yellow fj sent you(discount for you)..
Well I assumed the install of the Manik light bar would be easy. The hard part is getting the PIAA's mounted and wired. There are no instructions out there to do this. I've found many post on installing lights on a brush gaurd, but not to the roof rack. I hope the next person who installs lights to the roof rack, can post a photo tutorial.
the install of the lights was a total pita.... but i used this page to help me out: Preferred Roof Top Light Wire Routiing and btw, if you use the gobi directions (which is the best way if you only have 1 wire to run) remember to be careful when removing the a-pillar cover. i broke 4 out of 5 clips getting it off. now it sits weird and makes lots of wind noise.
i am going to drill a hole in the roof and weather proof it. that will def be the easiest way to do it.
