Old 04-02-2006, 08:21 AM   #11 (permalink)
Member Number: 342
Re: Fasten seatbelt
RoverGGM previously said:
Seat belt chime
1. Turn the ignition switch on (without starting car)
2. Press the ODO/TRIP switch until the odometer displays "ODO"
3. Turn the ignition switch off
4. Turn the ignition switch on
5. Press ODO/TRIP switch immediately (within 6 seconds after turning the power switch ON) and hold it down for 10 seconds or more.
6. Continue holding the ODO/TRIP switch and fasten the front passenger's seat belt.
7. Check that the odometer displays either "b-on" or "b-off" (it will be "b-on")
8. Press the ODO/TRIP button to change the display to "b-off".
9. Turn the ignition switch off.
10. Turn the ignition switch on while depressing the brake pedal.
11. Check that no buzzer sounds when setting on the front passenger seat.
So sayeth the mighty repair manual... your mileage may vary... items are sold by weight and not by volume, so settlement may have occured during shipment... professional driver on a closed course, do not attempt... etc., ad nauseum. This is not to be construed as legal advice, if you need real legal advice, consult a real lawyer....they need the money!
Love YA, Mean it!
Thank you so much Rover!
Slab is offline
Old 04-02-2006, 11:31 AM   #12 (permalink)
lukecruiser's Avatar
Member Number: 1501
Re: Fasten seatbelt
I alway fasten my seat belt.Did you know that my dad says that there is a little motor in the seat so when you crash instead of the seat belt just locking it lock you and pulls you back. You should thank p4cruiser cause he is my dad and he told me that.
lukecruiser is offline
Old 04-02-2006, 06:08 PM   #13 (permalink)
brianljohnson's Avatar
Member Number: 338
Send a message via MSN to brianljohnson
Re: Fasten seatbelt
I'm not sure I understand what you are talking about in getting hte ODO/Trip display to ODO with no numbers being displayed. Do you turn the ingnition switch to off very quickly when you get to the ODO display mode? Any news on whether this kind of procedure works on the drivers side seat belt?
I like my 93 FJ80 where all I have to look at is the seat belt indicator light on the dash to know I need to fasten it. Hopefully we can get the FJC to do the same.
Brian L Johnson
'74 FJ40
'93 FJ80
'07 FJ Cruiser
brianljohnson is offline
Old 04-02-2006, 11:58 PM   #14 (permalink)
Member Number: 338
Re: Fasten seatbelt
Call me stupid but I finally figured this out. I was trying to make this work for the passenger seat belt while executing the instructions from the DRIVERS SEAT. When I looked in the owners manual, it shows these instructions for both drivers and passenger front seat belt alarms/buzzers. The passenger seat belt buzzer settings can only be changed when you have someone sitting in the passenger seat. The drivers seat belt buzzer can be changed as well when you execute the instructions from the drivers seat.
With the B-Off setting configured, the drivers seat belt buzzer will only sound when you start when you first start your FJC. Subsequent buzzer sounds are eliminated by the b-Off setting. The passenger buzzer is eliminated completely when the b-Off setting is in place.
Happy cruising.
Brian L Johnson
'74 FJ40
'93 FJ80
'07 FJ Cruiser
Old 04-05-2006, 09:16 PM   #15 (permalink)
RoverGGM's Avatar
Member Number: 471
Re: Fasten seatbelt
Seat belt chime
Love YA, Mean it!
bump bump
RoverGGM is online now
Old 05-01-2006, 04:53 PM   #16 (permalink)
jtratza's Avatar
Member Number: 1739
Re: Fasten seatbelt
Rover, I owe you a beer. I followed the manuals instructions several times without success. Your's worked first time. Now how do you change the radio's display colors? Get that one right and I'll bet you can tell us the secret to getting lower gas prices.
jtratza is offline
Old 05-02-2006, 07:47 AM   #17 (permalink)
Member Number: 342
Re: Fasten seatbelt
That's in the manual. With Radio off, hold text button until text appears. Turn radio on turn small knob on right of radio to scroll through colors.
Slab is offline
Old 05-10-2006, 10:28 PM   #18 (permalink)
Tranman's Avatar
Member Number: 1053
Re: Fasten seatbelt
I have the stock stereo and not the upgraded 6disc player. The color is orange. I tried to change the color, but was unable to. I turned off the radio, then press the text button and held it. It never came on. Checked the manuel and it says it only works with the type 2 stereo? hmmm. Did get the seat belt chime to turn off after 2nd try using RoverGMs instructions. Thanks!
Tranman is offline
Old 05-17-2006, 12:30 PM   #19 (permalink)
Member Number: 2418
Send a message via AIM to Steven Knoblauch Send a message via Skype™ to Steven Knoblauch
Re: Fasten seatbelt
i will try it tonight to see if it works. that buzzer is nasty
RUTHLESS FJ
Steven Knoblauch is offline
Old 05-17-2006, 12:37 PM   #20 (permalink)
VTFJC's Avatar
Member Number: 1223
Re: Fasten seatbelt
Slab previously said:
One minor problem. When I lace my briefcase weighing about 20 lbs. on the passenger seat, sometimes it activates the annoying "fasten your seatbelt" beeper. Is it supposed to be this sensitive?
I had a similar problem- The way I take care of it is by drinking 5 beers. Works every time. Only its not a breifcase- for me its a twelve pack that sets it off.
VTFJC is offline
