I'm thinking of removing the new style oval toyota badge from the rear of my rig. I've always hated that thing since it was introduced, always preferred the old spelled-out "TOYOTA" instead. I just wish I could remove it from my steering wheel, too.
Has anyone done this, know how it's attached? Is it simply bonded with an adhesive, or is it more firmly attached or bolted on from the other side of the sheet metal? I'm going to take a gentle look at it with a plastic or wooden tool today, but thought I'd ask around. Any info appreciated.
TLCA#17822 / FCC:KD0ECN
'07-6MT-FJC...and a whole BUNCHA stuff.
My thanks to Budbuilt, Lucrum, URD, Tuffy, Springtail, KC, BFG, Valentine One, Cobra,
Engel, BFG, Cobra, Yaesu
Protest the end of poitical dialog by contacting
your favorite moderator(s)!
It's only an adhesive. Warm it up with a hair dryer and work a piece of fishing line behind it, sawing back and forth as you work the line all the way through. I have removed all of the badging and re glued that one on here What I did to the Toyota Emblem
"What is funny about us is precisely that we take ourselves too seriously"
It is just "glued" on with adhesive tape - if you warm it up with a heat gun or hair drier and use a plastic trim tool (or a poly putty knife) it should come right off with a little gentle pressure. Do make sure that both the tool and the surrounding area are clean before you do this - you don't want to be grinding any dirt into the paint.
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
I just used a hair dryer. Warmed it up a bit and then peeled the emblem right off. No fishing line or dental floss. It just peeled off. Don't get it too hot as you could damage your paint. Be patient.
__________________ -Jim
Founder/President NorthWest FJ Cruiser Club PDXTuning Dyno Pull Purchased: '07 BlackDiamond AT · UR2 · CQ · GY · C7 · EL · Skids · Sills · Rubber Mats Aftermarket: 265/70R 17 BFG ATs · Trail-Gear Sliders · FormFit Hood Protector · Matching Tint · AVS Visors · Dual PIAA Horns · ScanGauge II · Schrader's Flag Mount & Tri-Mount · BandiMount · Galaxy DX 45MP CB with Firestik II Mods:Lucrum Winch Mount & Warn M8000 — OME 3" Lift TRDStuff: Exhaust · Cold Air Induction
I second that, I washed my truck, but there was still some salt residue in the crevices of the emblems. So, I ended up with some micro-fine scratches that will certainly buff out. I don't know what kind of paint Toyota is using but my black iPod is more scratch resistant.
Good post Dragon, I too removed all my emblems from my vehicles in the past. I need to remove the Toyota emblem from my new FJ too. Thanks for reminding me
I just left mine out in the California sun (February) and it came off with dental floss. I prefer floss to fishing line as it isn't as likely to scratch.
bj
Thin Plastic Spatula. Be patient and make it one smooth single pass. It'll come off without a hair dryer. I removed both on the left rear, without so much as a mark. You can use your fingers to remove any leftover adhesive. All that is left is the FJ Cruiser on the right rear...
07 Black Cherry 4x4 AT
CQ, UP, C7, C8, GY, EL, RS3200, TRD CAI, door nets, cargo cover, 2nd horn, PIAA bulbs
BFG A/T KO's, Donahoe coilovers & rear shocks (stock rear coils)
I just peeled it off with my fingers. Used some glue de-adhesive for minor sticky stuff left behind. Dont pull too hard, as you could put a dent in the gate.
2004 F150
2004 CTS-V
2006 Z06
2007 TRD SE
Lars
