Old 04-22-2007, 09:17 PM   #1 (permalink)
MichEE's Avatar
Member Number: 7210
OEM aux light install
I put the PT297-35061 OEM aux light assy on yesterday; VERY easy install, clean and got a good deal from Genuine Toyota Parts and Accessories wholesale to the public. I thought that I would add a little mod I did and additional info for the instructions.
GENERAL notes:
I believe that the wire harness is available seperate under part numbers PT-35070-AS for the switch to the junction block and PT297-35070-LH for the wires to the lights. These are not confirmed so double check before ordering.
The wiring AND the lights are from Hella. If someone has a contact there maybe the wiring can be purchased direct to save some $$.
I did NOT buy the PT297-35062 $80 support bracket. I'll make one for $80 if I really need to. If I do I'll add that info here. I probably will since I need a flag mount for the dunes.
SWITCH LOCATION:
I did not tear the console apart and so I installed the switch to the left of the steering column. This was a much easier install. The vent and cover to the left comes off easily with a good tug; no screws at all! I reached in and popped out the switch blank.
WIRING:
The t-taps go on the green wire and the green-white wire just as the instructions state but I tied into the light dimmer - rheostat. The hard part was getting a hand in to squeeze the connector on the back of the dimmer. After this was out I pulled back the tape on the wires and clipped on the t-taps.
The 13 pin connector (step 2h) was real tough to get into the junction block. Aside from needing to be a contortionist to get to it the other wires were in the way and I needed 4 hands. This was when I had to have my first beer break! I coiled the extra wire up and wire tied it into the corner of the dash.
UNDER HOOD
The under hood part was a breeze. The connector was just outside the firewall on the driver's side fender - not real clear in the instructions.
Make sure that the fuse goes into the 3rd slot from the end. I got mine in the 2nd and it does not work at all from there!! The top of picture in the instructions is the driver's side of the vehicle.
I took out the grill AND the plastic radiator support. That way I could wire tie to the existing wiring easier.
LIGHT MOUNT
Since I did not buy the OEM mount for the lights I just drilled a hole in the front most hole for the light mount. I did this from underneath so that I would make sure and drill in the center of the hole. Once I had the holes in the right place and the wiring where it needed to be I mounted the lights - a mistake!! The grill needs to go on FIRST and then the lights. There's not enough room between the lights and the grill to mount it once the lights are on the bumper. So, I took the lights off and THEN put the grill on and THEN put the lights back on.
I need to aim them and then drive a little to see if there is vibration. If so then I add the support and extra brackets.
Sorry only a few pics. It was busy today and dark now. I'll try and post some pics in the next week.
What's your excuse??? Ti, 5AT, Hand Controls, hitch, 10sNE1?
MichEE is offline
Old 04-28-2007, 08:32 AM   #2 (permalink)
RomaBoy's Avatar
Member Number: 2866
Re: OEM aux light install
Wow, the wiring is already there that's something I didn't know. I want to hook up fog lights to my bull bar so more photos would be great especially the oem wiring. Thanks a lot for the pdf file!
RomaBoy is offline
Old 04-28-2007, 09:51 PM   #3 (permalink)
MichEE's Avatar
Member Number: 7210
Here are some pics I got today with the lights on
and with the covers on
I don't like the covers. Kinda tacky. I'll paint them all black at least. Maybe they'll look like this??
MichEE is offline
Old 04-28-2007, 10:22 PM   #4 (permalink)
gj07fjc's Avatar
Member Number: 2192
or you could get these Hellas Grill Covers
picture from this thread by Slow35th
I'm sure those FJ covers will do well on Ebay
07 Black Diamond MT6, 'A'-PKG.
gj07fjc is offline
Old 04-28-2007, 11:04 PM   #5 (permalink)
MichEE's Avatar
Member Number: 7210
gj07fjc previously said: View Post
Hmmm.... thanks for the info. I wonder if I can get something without the Hella on it...???
MichEE is offline
Old 04-28-2007, 11:51 PM   #6 (permalink)
gj07fjc's Avatar
Member Number: 2192
MichEE previously said: View Post
from Slow35th post,
No part number. They were just in the isle with the off road lights. Lots of places have them online but they were the cheapest at Pepboys and no shipping. BTW, If you don't like the Hella logo on the front, It just snaps on and off. .
I am just waiting for mine to arrive
gj07fjc is offline
Old 04-29-2007, 12:23 PM   #7 (permalink)
Slow35th's Avatar
Member Number: 9940
from Slow35th post,
Yep, the little Hella logo just snaps on and off. I tried it booth ways and liked it best with the logo on. You could even paint the logo black if you wanted, they are Hella lights after all.
Slow35th is offline
Old 12-02-2007, 12:38 PM   #8 (permalink)
speedy's Avatar
Member Number: 3087
I have a question. So you used the OEM wire harness that connects underneath the hood by the driver side to the lights. Did you have to cut the end off in order to connect them to the Hella's? If I were to go with another brand of lights could I buy:
1. OEM Aux light switch,
2. OEM aux light wire harness interior (without pigtails)
3. OEM aux light wire harness under the hood (fab some pigtails to connect to the off road lights)
I have seen some wire harness for the interior that has the pigtails but not sure what those are for.
Thanks,
speedy is online now
Old 12-20-2007, 07:34 AM   #9 (permalink)
r71
r71's Avatar
Member Number: 9462
GENERAL notes:
SWITCH LOCATION:
WIRING:
UNDER HOOD
LIGHT MOUNT
According to the instructions, it says you can only operate these with highlights. Has anyone installed these and tapped into the low beam?
r71 is offline
