Old 05-15-2007, 04:15 PM   #1 (permalink)
FJ-JJ's Avatar
Member Number: 11357
Yet Another DIY Dam Thread......
Well, I had these parts laying around, so decided to use them.
Yakima Bar and Dam mounts, Yak fairing was cracked
Thule Air Dam/Fairing
I wanted a super low profile, and only wanted the bar to hold the dam, not be load bearing. I used info gained from my mountain biking background to figure out a way to attach nuts inside the tube, a neat little thing called a Star Nut, that slides into a cylinder then won't come out under load. It has a threaded nut in it's center. First I beveled the tube ends on a grinder, to better fit the Rack profile. then i went to a local bike shop, and had them set one nut in each end. You can do this yourself, but its easier with the right tool...
[IMG][/IMG]
Here you can see the bolt in place, and the bevel.
[IMG][/IMG]
Then I located the spot on the factory rack where I wanted the tube to live, and I drilled a hole big enough for the head of the bolt to go into from the outside, but just big enough for the shaft of the bolt on the inside, held the bar and threaded the bolt through the rack, and into the star nut. tightened both sides and presto!!
[IMG][/IMG]
[IMG][/IMG]
Then I mounted the dam/fairing.
[IMG][/IMG]
TLCA #17522
'07 Black Cherry, Born on 03/07
5 Spd Auto
Conv. Package
Upgrade Package 2
Roof Rack with Home Made Thule Air Dam mount
Towing Hitch
Spare Tire Cover (sitting in the garage... Revo's too pretty to hide!!!)
All weather Mats
Trail-Gear Sliders, Line X'd
New Sneakers...Revo's...
No more DRL's
No seatbelt reminders on Passenger seat
FJ-JJ is offline
Old 05-15-2007, 04:29 PM   #2 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: Yet Another DIY Dam Thread......
Dam good work. Looks great!!
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 05-15-2007, 04:32 PM   #3 (permalink)
undertow's Avatar
Member Number: 4469
Wow clean look.
great imagination.
db
undertow is offline
Old 05-15-2007, 04:38 PM   #4 (permalink)
FJ-JJ's Avatar
s hot from underneath
[IMG][/IMG]
and final front
[IMG][/IMG]
TLCA #17522
5 Spd Auto
Conv. Package
Upgrade Package 2
Towing Hitch
All weather Mats
No more DRL's
FJ-JJ is offline
Old 05-15-2007, 04:39 PM   #5 (permalink)
rbc24123's Avatar
Member Number: 10926
Looks good. Has it helped with wind noise? How about fuel economy?
07 FJ Titanium AT5 4WD CQ,Up#2,OEM Rack (Born: 04.07.07)
Mods [done]: Demello sliders, Cobra 75WXST+Bandi
Mods [to do]: Tires/Wheels, Suspension+UCA, Front Bumper+Winch+fogs, Extra lights, 2m radio, Blackout handles+mirrors
____________________________________________
member: treadlightly!
http://i269.photobucket.com/albums/j...o3-smaller.jpg
rbc24123 is offline
Old 05-15-2007, 04:50 PM   #6 (permalink)
RavenFJ's Avatar
Member Number: 8451
Oooohhh fer the love 'o' Pete, now I gotta......Oops, nevermind, don't have a rack. Good job, carry on....
RavenFJ is offline
Old 05-15-2007, 04:52 PM   #7 (permalink)
FJ-JJ's Avatar
Freakin' rack still roars as far as I'm concerned, but it is quieter, but it may also be the Revo's making more noise than the Stock tires. I did both at the same time, so hard to tell. I'm getting 18-19 MPG, on it's first 1000 miles, so hopefully it'll loosen up and get a little better. By the way I don't care. I love this truck!!!
TLCA #17522
5 Spd Auto
Conv. Package
Upgrade Package 2
Towing Hitch
All weather Mats
No more DRL's
FJ-JJ is offline
Old 05-16-2007, 08:10 PM   #8 (permalink)
FJR Colorado's Avatar
Member Number: 1361
Truly cool and innovative.
What model Thule is that? Still available?
What could be even cooler is to use that Thule plexiglass as a template and cut a piece of aluminum to the same size. Then, paint it white and put a black FJ logo in the corner.
You said that tubing was from an old Yakima fairing... Is that stuff available at custom bike shops (like the one where you got the spider nuts)?
FJR Colorado is offline
Old 05-16-2007, 08:32 PM   #9 (permalink)
firemanj92's Avatar
Member Number: 11130
FJR Colorado previously said: View Post
Try Thule 555 fairing. You should be able to find at a LBS (Local Bike Store) as it is no longer made. Only found one bike shop online with some availability.
Yakima and Thule crossbars can also be found at your LBS or REI. The "star nuts" are used to secure the fork to the stem of a bike also at LBS.
Hope this helps-J
firemanj92 is offline
Old 05-17-2007, 05:46 AM   #10 (permalink)
FJ-JJ's Avatar
Fireman is right, the fairing is an old one, probably 5-6 years old. Good luck finding one. They are out there, but will probably be covered in dust.
If I were to fabricate my own, I'd probably make it long enought to slightly overlap the factory rack, I may be getting some noise from the ends. I may throw some tape over the joint to see if it makes any difference, then if it does figure out a wing or extension to the fairing
The Yak tube however is a standard 48" bar, that I cut down and then beveled.
You don't need to go to a "custom" bike shop, just go to a real bike shop, (a good mechanic at a mass merchant like sports authority or walmart might know what a star nut is, but any true bike shop will have a little tray of them on their parts bench.) It's a standard issue item for any store that has to replace a modern bike fork, suspension or otherwise.
TLCA #17522
5 Spd Auto
Conv. Package
Upgrade Package 2
Towing Hitch
All weather Mats
No more DRL's
FJ-JJ is offline
