Runt previously said:
Landcruisersteve.....could you please do me a favor and measure the outer, side to side distance on your drawer and the outer boxes inner dimensions. Space provided by the drawer rails between the inner and out part would be handy as well.
Runt,
The outside side-to-side width of the drawers are exactly
19".
The inside side-to-side width of the drawer compartments are
20".
And, the space between the drawer sides and the drawer compartment inner walls are
1/2" on each side (to accomodate the thickness of the drawer slides). This is assuming that the center divider section is
3/4" plywood. (If you're using 1/2" plywood, adjust your width measurements accordingly.)
The best way to guarantee proper measurements, is to build the outside box first (leaving the top off for the time being). Then attach your drawer slides to both the inner compartment walls and the outside of the already cut-to-depth drawer sides.
Install the drawer sides onto the inner walls, and
then measure and cut your drawers front and rear panels. This will ensure that you have slideable drawers' that will fit the width of the inner compartments.
Anyway, be sure to post up your completed project when it's done. I'm looking forward to seeing how you set up your gun mount system.
