Old 06-30-2007, 09:19 PM   #1 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Roof rack crossbar mod: 3 is stronger than 1 (pics)
It's not that the OEM roof rack crossbars are completely worthless. They just have difficulty supporting too much weight when they're separated from each other.
Seeing some posts where jerry cans were mounted atop of one or two crossbars, I figured that combining three of them side-by-side would provide an ample support system. And, it certainly does!!
The only problem is, there's not quite enough room at the back of the rack to put three in a row between the two rear vertical pillars, so some slight modification to one of the crossbars will have to be done.
Since a couple of the crossbars are slightly different in length, pick two that go together perfectly, and pick a third that fits across the top tier just ahead of the support pillar. The remaining cross bar will have to be shortened (cut), and in doing so, you'll have to use two self-tapping screws to replace the original torx head screws.
That particular crossbar will have to be notched to fit behind the support pillar. (Be sure to notch it on the forward side as indicated by the arrow on the mount.)
Once mounted, you’ve got yourself a VERY strong cargo area that even supported the weight of this 245-pounder sitting on it. (Sorry, I couldn’t take a picture of myself at the same time.) So, a couple of full jerry cans (or more) shouldn’t have any problem at all. (Obviously, provisions for tie-down straps will have to be added for securing the jerry cans.)
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 06-30-2007, 10:10 PM   #2 (permalink)
suncruiser's Avatar
Member Number: 11281
Re: Roof rack crossbar mod: 3 is stronger than 1 (pics)
always strength in numbers. my only thing is the most i would put up there is a baby stroller. gonna have to do that next week when we pack up for vacation. just curious, not to hijack, but how would you strap anything down up there, bungees', or ratchet straps??
285/70/17 BFGs, chrome moto 951
toytec "3 lift
a-trac installed
demello sliders
vent visors
http://www.myspace.com/kgries
http://www.cardomain.com/ride/2639123
http://www.4x4country.net/register.php?REF=9118
suncruiser is offline
Old 06-30-2007, 10:14 PM   #3 (permalink)
Member Number: 8627
suncruiser previously said: View Post
I'll probably be putting a couple "eye-bolts" on the center crossbar for rachet straps.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 07-01-2007, 08:33 PM   #4 (permalink)
therelaxer's Avatar
Member Number: 10832
Nice mod!!
I will have to remember this mod. How did it take? How much did you cut off and what did you use to cut the crossbar?
Keep us updated with your tie down positions and how it performs on the trail.
over and out,
I wanted to say more, but my dad taught me if you argue with an idiot, no one could tell the difference.
Over and out.
OME lift, Steelies on 285 BFG's,Bud-built,Airaid,Demello bump & slider.
therelaxer is offline
Old 07-01-2007, 08:37 PM   #5 (permalink)
Admudistrator
Dragon's Avatar
Member Number: 2479
Nicely done, Steve. I was just contemplating this today.
We are not at our best perched at the summit; we are climbers, at our best when the way is steep.
-John W. Gardner
Click
Dragon is offline
Old 07-01-2007, 09:42 PM   #6 (permalink)
Banned
Sun Fusion Cruiser's Avatar
Member Number: 3655
Looks clean, Steve.
You da Man!!!
Sun Fusion Cruiser is offline
Old 07-02-2007, 09:33 AM   #7 (permalink)
Member Number: 8627
therelaxer previously said: View Post
Just under a half inch. Used a hack saw.
You'll know it's just right when you can see the first OEM screw hole peeking halfway through the slide groove. (The second OEM hole was used for one of my self-tapping screws. The third hole in, I drilled.)
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 07-02-2007, 06:17 PM   #8 (permalink)
Member Number: 8627
Final touches:
I added the eye-bolts to the center crossbar spaced at exactly 9 5/8" from one another (starting at the edges of the crossbar mount). Be careful when tightening the eyebolts. Tighten just enough to collapse the lock washer. Beyond that will start collapsing the crossbar itself.
The spacing was based upon the width of the Blitz plastic gas cans with the self-venting cap.
The spacing worked out to accomadate three of the Blitz gas cans. (Sorry, I didn't have a third one for the photo op.) Two cans can be individually ratchet-strapped . . . . or if three cans are used, a single rachet-strap can go through all three handles.
To test the integrity of this gas can rack mount set-up, I filled each can to capacity and drove the FJ to and from work. No shifting, no crossbar sagging, no spilling and no wind noise.
Short of upgrading to a heavy-duty aftermarket rack, this does the perfect job of supporting and carrying that additional 15+ gallons of spare gas.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 07-02-2007, 06:22 PM   #9 (permalink)
PMSteve's Avatar
Member Number: 10892
LC Steve:
Nice pics and a good idea! Even though the stock rack looks sturdy, I always suspected that it was more for "Show" than "Go".
PM Steve
Black Diamond Club
Whale Oil Beef Hooked
TLCA Member # 17449
'07 Black Diamond Base Model w/ Convenience Pkg, Automatic Trans.,
Tow Pkg., Roof Rack and none of them 'stinkin useless gauges on the dash.
PMSteve is offline
Old 07-02-2007, 06:47 PM   #10 (permalink)
Silverdusk's Avatar
Member Number: 4660
Another fabulous job Steve, most impressive. Great having guys like you on this forum bringing us new ideas.
Silverdusk is offline
